Hi fellas! back in here for a new quistion..
I have a ASUS M3A78, thats my MOBO, and currently im using a AMD Phenom II X4 810 @2.60ghz, the deal is that im playing with 8gb of ram and a Gigabyte 660 Ti OC version, great gpu, very powerfull, but with the cpu i have frame drops..
For example, im plying skyrim at 1920x1080p, everything maxed out (in game configurations, and card manage 3D) and im haveing 50-60fps, (with amd cpu) and a friend its playing with same card, same ram, same resolution but an i5 and the fps are moooooooooooooooooore high, about 95+
So.. wich cpu you think is the best for my mobo? i dont wanna change the movo because if i change that i have to change ram's etc, to expensive.. so if everyone know of some cpu better than mine, that fit the mobo, plz tell me!
thx, PzyDuck
PD: I wanna to overclock, with a cpu cooling, of course
thx, PzyDuck
