Need help with crashing computer. BSOD + Kernel-Power 41
inerax
1,266
130
Hello all i have been trouble shooting a problem for a good 6 months now and cannot find it.
im about to just start over because i hate this.
I am getting Kernel-Power 41 Critical system fails.
It is giving me a BSOD or freezes the computer completely and i have to click the reset buttion.
I RMA'd my MOBO thinking that was it, so i have a fresh MOBO.
Friend let be borrow his RAM, CPU, GPU. Tested and still happened.
It happens the most when i am running the prime95 torture test.
New mobo, happens on both CPU, GPU and ram sticks.
I have tested the HDD's with no errors.
only think left is the PSU or MAYBE another bad MOBO????
can someone tell me if a bad PSU can cause this problem??
or what i can try next?? i have taken my system out of raid 0 and just have a main and slave HDD.
specs below.
Windows 7 x64 ultimate
MSI 790X-GD70
AMD 3.4ghz 965 black
EVGA 9800GTX
Dual 1TB WD Carver Black
4GB (only using 2gb ATM) munchkin
have extra fans and cooling for CPU
PSU is
Rosewill BRONZE series RBR1000-M 1000W Continuous@40°C, 80Plus Bronze Certified,Modular Cable Design,ATX12V v2.3/ EPS12V,SLI Ready,CrossFire Ready,Active PFC"Compatible with Core i7, i5" Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182188
if i left anything out please let me know.
Please if someone can turn me in the right direction to fix this i would be grateful
- System
- Provider
[ Name] Microsoft-Windows-Kernel-Power
[ Guid] {331C3B3A-2005-44C2-AC5E-77220C37D6B4}
EventID 41
Version 2
Level 1
Task 63
Opcode 0
Keywords 0x8000000000000002
- TimeCreated
[ SystemTime] 2010-11-13T16:00:07.221630900Z
EventRecordID 1868
Correlation
- Execution
[ ProcessID] 4
[ ThreadID] 8
Channel System
Computer Ross-PC
- Security
[ UserID] S-1-5-18
- EventData
BugcheckCode 0
BugcheckParameter1 0x0
BugcheckParameter2 0x0
BugcheckParameter3 0x0
BugcheckParameter4 0x0
SleepInProgress false
PowerButtonTimestamp 0
inerax
1,266
130
I have ran memtest.
Even ran multi memtest's for extended time.
I thought memtest was to check if the memory (ram) was bad by loading data into the ram not the motherboard.
inerax
1,266
130
Just ran memtest again, no problems.
I also ram Memtest86+.
it went to a screen before bootup and ran.
complete with 0 errors found.
Does this rule out the ram?
what else can i test?
inerax
1,266
130
im on a fresh reformat of win7 x64. i dident even install audio drivers they auto installed with windows 7.
how can i check what audio divers are installed??
my cpu temp is good. never gone above 49 under HEAVY load. then freezes.
inerax
1,266
130
ok, i found 2 audio drivers.
one is High Definition Audio Bus Diver
the other is High Definition Audio Function Driver.
could they be messing with each other?
below is both lines from the program DriverView.
HDAudBus.sys 0xfffff88003ec5000 Sound Driver High Definition Audio Bus Driver 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Corporation Microsoft® Windows® Operating System 7/13/2009 5:06:13 PM 7/13/2009 5:06:13 PM C:\Windows\system32\DRIVERS\HDAudBus.sys A
HdAudio.sys 0xfffff88005164000 Sound Driver High Definition Audio Function Driver 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Corporation Microsoft® Windows® Operating System 7/13/2009 5:07:00 PM 7/13/2009 5:07:00 PM C:\Windows\system32\drivers\HdAudio.sys A
inerax
1,266
130
another line i have found is
Microsoft Trusted Audio Drivers.
could this be causing it?
drmk.sys 0xfffff88005000000 Dynamic Link Library Microsoft Trusted Audio Drivers 6.1.7600.16385 (win7_rtm.090713-1255) Microsoft Corporation Microsoft® Windows® Operating System 7/13/2009 6:01:25 PM 7/13/2009 5:06:30 PM C:\Windows\system32\drivers\drmk.sys A
Similar threads
