Need help with Crosair 570X case fan management
mosesyyy
Hi there, I plan to build a pc for my first time.
Here's the list:
CPU: Intel - Core i7-7820X 3.6GHz 8-Core Processor ($599.00 @ B&H)
CPU Cooler: Thermaltake - Water 3.0 Riing RGB 360 40.6 CFM Liquid CPU Cooler ($157.99 @ SuperBiiz)
Motherboard: MSI - X299 GAMING M7 ACK ATX LGA2066 Motherboard ($399.00 @ B&H)
Memory: Corsair - Vengeance RGB 32GB (4 x 8GB) DDR4-3000 Memory ($312.99 @ Amazon)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive ($219.99 @ Amazon)
Storage: Crucial - MX300 1.1TB M.2-2280 Solid State Drive ($275.99 @ SuperBiiz)
Video Card: EVGA - GeForce GTX 1080 Ti 11GB FTW3 GAMING iCX Video Card ($778.99 @ SuperBiiz)
Case: Corsair - Crystal 570X RGB White ATX Mid Tower Case ($179.99 @ Newegg)
Power Supply: SeaSonic - PRIME Titanium 850W 80+ Titanium Certified Fully-Modular ATX Power Supply ($178.89 @ Newegg)
Total: $3102.83
Generated by PCPartPicker 2017-06-20 01:18 EDT-0400
Plan to do some decent overclock with both CPU and GPU. I did a bit research and seems like many people would recommend to put the radiator on the front as air intake, and top/back for exhaust. Now I really don't know how to install all these fans. The case itself comes with 3x120mm on the front, and I get 3 more with the cpu cooler, so 6x120mm fans total but the top of the case won't support 3x120mm.
What should I do? Remove one and just put 2 on the top? If so should I use the stock fan on the front, or use ones with Thermaltake? Or should I just get the 240mm radiator instead and use these 2 fans on the top? If so how do I install it with 3x120mm on the front?
I'm totally lost please help~
So the case will only take the 360mm radiator in the front, so thats where it has to go. I'd put that with the thermaltake fans in the front, then move the corsair fans to the 2 top slots and one rear slot. So air flows in through the front and out through the top and rear. This will get the most consistent look, and will be easy to do.
Looking at your budget, its seems 'large' to say the least. Could I recommend a custom water loop? It would not only give you much better temps across the system for overclocking, but it would look the best, especially in the tempered glass case. Just a thought
