I just purchased a 2nd 7870 to pair up with my Sapphire 7870 GHz 2GB OC. I purchased an Asus 7870 DirectCU II v2.
They seem to work fine in Crossfire, but I'm running into a heat issue all of a sudden with the Sapphire.
I left the Sapphire as the primary card and set clock rates to stock on both cards (note: the Sapphire GPU/Memory stock clock is 1050/1250 - so 5GHz effective - and the Asus is 1000/1200). When running FC3 I found that the Sapphire got up to 76C; running alone this card has never breached 67C based on my HW Monitor records. The Asus never got above 59C, even though in FC3 it was at 98% GPU usage.
I'm wondering if swapping them would take this down a bit? I actually shut down FC3 once I saw the temp hit 75 on the Sapphire to prevent any issues. It dropped very quickly, but I'm sure it would have gone higher.
Any suggestions?
Any suggestions?
