I am in the process of building my next build, and I am looking to go full out custom liquid cooling.
I will link all the parts that I am looking at getting so far.
I pre-ordered the NZXT H440 White case. for $119.99
Case: http://www.nzxt.com/product/detail/143-h440-performance-mid-tower.html
Processor: Intel i7-4770k (Got it for $99.00) for Intel Certification 😀 http://www.newegg.com/Product/Product.aspx?Item=N82E16819116901
Motherboard: Asus Maximus VI Hero
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131989
Video Card: EVGA 780ti http://www.newegg.com/Product/Product.aspx?Item=N82E16814487001
PSU: EVGA 1000w http://www.newegg.com/Product/Product.aspx?Item=N82E16817438010
SSD: 120 Gb Corsair Force GT
HDD: WD Black 2TB
I am new to custom cooling, and really need recommendations as far as what waterblocks are good, what metals to use, what size tubing and fittings I need, what kind of fittings are better, what pump, and reservoir. I know the cooling might get expensive, so I'm looking for recommendations, on what the best set up would be, also I want to keep the color scheme black and red if you couldn't tell already, and also is it bad to use UV dye? or just stick with the tubing instead?
Thanks guys, I look forward to seeing your advice.
HDD: WD Black 2TB
