Need Help with Deciding on What CPU Cooler to Get
TheAznKamikaze
Hi. This is the parts list for my gaming/work build
http://pcpartpicker.com/p/2mET2
I want to get the Corsair H100i, but I'm really hesitant. After doing a lot of research, I've seen some problems that worry me. Some people say that the H100i is incompatible with the AsRock Extreme 4 because the mounting doesn't work or it interferes with the RAM. I just want to know whether anyone knows if the H100i would work with my components or if I should get a different cooler. If anyone has a good air or water cooler that would work well or even better than the H100i for my build then I'd be happy to consider it. Thanks.
