[SOLVED] Need Help with Directions Given to me (MAC)
  • Thread starter Thread starter Guest
  • Start date Start date
The /Libraries folder (in your home folder) is hidden.
Open Finder, select Go (menu bar) then Go to Folder (bottom of the menu), and cut-and-paste the address (with the relevant [your user name] substituted.
If you get stuck with that, find someone who can do it for you, /Libraries is hidden for a reason.
