C Carmichael_12 Reputable Jul 29, 2014 59 0 4,630 May 9, 2015 #1 http://ca.pcpartpicker.com/p/LBwgxr So this is my build can someone link me to the drivers and explain how I install them ?
Solution mcnumpty23 May 9, 2015 yes sounds all right you could just have added a folder for the drivers to the usb you use for your windows iso once the windows installation was on it and personally for bootable usb i prefer yumi over the Microsoft tool
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 May 9, 2015 #2 the parts will come with driver disks or download them from the makers site Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 171,444 17,908 184,590 May 9, 2015 #3 Carmichael_12 : http://ca.pcpartpicker.com/p/LBwgxr So this is my build can someone link me to the drivers and explain how I install them ? Drivers come from each manufacturer. The motherboard and GPU will include a CD will all the drivers you need. Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 May 9, 2015 #4 you do realise thats an extremely long video card dont you? Upvote 0 Downvote
C Carmichael_12 Reputable Jul 29, 2014 59 0 4,630 May 9, 2015 #5 Yes I realize the card is very long Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 May 9, 2015 #6 Carmichael_12 : Yes I realize the card is very long ok--not familiar with that case was why i asked wasnt sure if you might need to remove drive bays to fit it Upvote 0 Downvote
C Carmichael_12 Reputable Jul 29, 2014 59 0 4,630 May 9, 2015 #7 The case does not have a optical drive , so how would I install the drivers ? And with my particular motherboard when I look at the drives it shows rev 1, 1.1 and 1.2 Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 May 9, 2015 #8 install them from a flash drive,external drive,by connecting a second hard drive internally main thing is get the driver needed for the internet before installing windows--with that all the others can be downloaded how are you going to install windows with no dvd/cd drive? Upvote 0 Downvote
C Carmichael_12 Reputable Jul 29, 2014 59 0 4,630 May 9, 2015 #9 I have another PC I'm going to buy a usb and create a ISO use the Microsoft tool to make it bootable , and set the bios to boot from that usb Upvote 0 Downvote
C Carmichael_12 Reputable Jul 29, 2014 59 0 4,630 May 9, 2015 #10 And I got all the drivers on a different usb , rev 1.2 for Windows 8.1 with all of the drivers installed on it Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 171,444 17,908 184,590 May 9, 2015 #11 Carmichael_12 : And I got all the drivers on a different usb , rev 1.2 for Windows 8.1 with all of the drivers installed on it Then you have no problems, right? Upvote 0 Downvote
C Carmichael_12 Reputable Jul 29, 2014 59 0 4,630 May 9, 2015 #12 I'm just trying to make sure I have the right drivers , does that all sound right ? Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 May 9, 2015 Solution #13 yes sounds all right you could just have added a folder for the drivers to the usb you use for your windows iso once the windows installation was on it and personally for bootable usb i prefer yumi over the Microsoft tool Upvote 0 Downvote Solution
C Carmichael_12 Reputable Jul 29, 2014 59 0 4,630 May 9, 2015 #14 Alright I'll take a look at yumi thanks guys Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,519 0 66,960 May 9, 2015 #15 no problem yumi is here http://www.pendrivelinux.com/yumi-multiboot-usb-creator/ Upvote 0 Downvote
