I have a Gigabyte G1 GTX 970 and a MSI Z97s Krait motherboard. I just found out that in order to go dual monitor you must have both monitors sourcing from a single output. This means I can't have my newer monitor hooked up to the GPU and older monitor hooked up to motherboard. Since I can't source from two different outputs I need to buy a cable to hook up both monitors to my GPU. The problem is that I don't know which cable to get. My other monitor is pretty old and only has VGA and DVI-D. My GPU has DVI-D, DVI-I, DP (x3), and an HDMI (which is currently being occupied by my new monitor). With all these options which cable do I buy? Should I get a:
DVI-D to DVI-D
DVI-D to DVI-I adapter
DVI-I to DP adapter
VGA to DVI-D
VGA to DVI-I
VGA to DP
etc
