Need help with execbuild
G
Guest
Guest
Archived from groups: alt.games.microsoft.flight-sim (More info?)
I have tried to exclude som buildings at St Barthelemy airport and
have been able to generate sourcecode and save sourcecode and
generate bgl, but here's where the problem is. I can't generate a bgl
only a xml which I put in the folder where I have BGLComp_SDK, but if
I try to execute bglcomp.exe nothing happens, and no bgl file is
created. I do have the MSXML4 installed which apparently is required.
Any help will be appriciated
Falcon
> created.
Don't try to "execute bglcomp.exe" at all; simply drag the edited .xml file
in Windows Explorer and drop it on bglcomp.exe...
Bill
I'm no scenery builder,but I have a recollection from somewhere that you
drag the source file over the bglcomp.exe icon and it then runs,using the
source file as info and should produce a bgl
file................................................I think
Bryan
"Falcon" <falcon1@email.dk> wrote in message
news:rdc6219btgci4agba7qkd2nanddqpa5auj@4ax.com...
> Falcon
On Tue, 1 Mar 2005 16:48:55 +1100, "Bryan" <nosoupforyou@spamcity.com>
>Bryan
I've done what you and Bill suggested and I can see in a flash that it
creates something, but I can't find the bgl file anywhere. The
sourcefile was called tffj.xml and I assume that the created file
would be called tffj.bgl, but after having searched all of my HD, I
can only find one file with that name, and thats the original file in
the addon/scenery dir.
Falcon
Is your tffj.mdl file in the same folder as the tffj.xml file? If not, is
the path in the .xml file to the tffj.mdl file correct?
As an alternative to drag-n-drop, open a "Command Box" (what used to be
called a "DOS Window!") and CD (change directory) to whichever folder (used
to be called "directory") that BGLComp.exe is located.
Type the following and press enter:
bglcomp.exe tffj.xml tffj.bgl
You will be able to read any error messages that way.
Bill
On Tue, 1 Mar 2005 09:01:45 -0500, Bill Leaming <n4gix@comcast.net>
wrote:
Hi Bill
Hmm, I don't have a tffj.MDL file just a tffj.XML
> If not, is
>Bill
There's certainly something wrong cause I get this when executing the
DOS command:
Parsing document: tffj.xml
ERROR C2345: LongitudeMinimum MUST be less than LongitudeMaxim
ERROR C2031: Failed element parse <ExclusionRectangle>
ERROR C2032: XML Parse Error! Element tree follows:
ERROR: <FSData
ERROR: version = 9.0
ERROR: >
ERROR: <ExclusionRectangle
ERROR: latitudeMinimum = N17 54.14
ERROR: latitudeMaximum = N17 54.37
ERROR: longitudeMinimum = W62 50.58
ERROR: longitudeMaximum = W62 50.78
ERROR: excludeGenericBuildingObjects = TRUE
ERROR: excludeLibraryObjects = TRUE
ERROR: >
ERROR:
ERROR: Compilation errors detected, compilation failed!
Parse complete!
ERROR C2002: Failed to find files: (tffj.bgl)
AS I'm no wizzard (as you might have found out 🙂 ) I don' excately
know how to correct this????
Falcon
Sorry. I had a brain fart there for a moment. Excludes don't have .mdl
files! <insert embarrased grin here>
Although it seems silly, reverse the two longitude values. In the West,
larger numbers are actually smaller... 😉
Bill
