Need help with fan curve (2 cpu + 6 case).
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I have my R5 1600 at 3.8GHz with 1.3125V, my case is the Corsair 400C and my cpu cooler is the Arctic Freezer 33.
There are 2 Arctic F12's (PWM) on the cpu cooler, and 6 more on the case (3 front intake, 2 top exhaust, 1 rear exhaust).
The chassis fans are connected to a Deepcool FH-10 fan hub which is powered by sata and connects to the motherboard via a single pwm header, so all of them will run at the same speed.
So the question is how do i setup the fan curve correctly. (im not a noise freak, but i dont want it being too loud)
Right now its 30% up to 30C, 50% up to 50C and 70% up to 70C... i dont think thats the best solution.
(around 35C at idle, 50C with Aida64, 65C with Prime95)
