Need help with fan setup
jere__
24
EDIT: so are these fans enough with this gaming build? Obviously im not overclocking cpu, but maybe gpu instead, if thats possible with this build?
https://pcpartpicker.com/list/DrcsCy
Noctua nf-a14 140mm (front intake)
Arctic f12 120mm (rear exhaust)
If those two fans r not enough, maybe i should go 2x arctic 120mm (front)
Or 2x 140mm noctuas (front)
Or are those 2 140mm fans gonna be very loud?
That case comes with 2 decent enough fans preinstalled
Those will usually suffice
If you got the extra fans - you can install them
But no need to buy them
Try building your pc in here: https://pcpartpicker.com/
You will see any compatibility issues
if you don't plan to overclock then that's fine.
