Hi guys!
In the process of building my first gaming PC and I had the thought that I do actually want RGB in it. This is my build so far. I have all the parts and am in the process of putting it together. I am looking at adding in some extra case fans. I want to move the back Fractal Design case fan to the front of the case and then install 3 RGB fans. Two on the top and one at the back. I don't really like the look of the RGB on the front mesh so thats why I'm leaving the two stock fans for there. Any help in the following would be hugely appreciated;
1) Does the mobo has enough inlets or sockets to support all 5 fans (3 RGB and two stock non RGB).
2) Do I need splitters for the fans and can I run it all from the PC instead of having a remote
3) Is this a stupid idea???
4) I was looking at CoolerMaster 120mm MF120R Addressable RGB fan with Control - 3 Pack, however like I said, id prefer to not have the control and have everything run from the mobo/computer software. Link for the fans is https://www.umart.com.au/Cooler-Mas...-RGB-Fan-with-Controller---3-Pack_50073G.html
5) I also do like the look of the Corsair QL120 and Corsair LL120 however, at AUD $150/$145 it seems a bit steep.
6) Suggestions on decent/cheap RGB fans that still look good and will fit in my case, if the above fans are not recommended
7) Links to additional parts that I will need to install?
8) Will the fans fit at the top with the Dark Rock Pro 4 installed. Seems to be little room there.
PCPartPicker Part List
Type | Item | Price |
CPU | AMD Ryzen 7 3700X 3.6 GHz 8-Core Processor | $524.70 @ Newegg Australia |
CPU Cooler | be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler | $139.00 @ PCCaseGear |
Motherboard | MSI B450 TOMAHAWK MAX ATX AM4 Motherboard | $215.00 @ Computer Alliance |
Memory | G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory | $150.70 @ Newegg Australia |
Storage | Crucial P1 1 TB M.2-2280 NVME Solid State Drive | $182.00 @ Skycomp Technology |
Video Card | MSI Radeon RX 5700 XT 8 GB GAMING X Video Card | $766.70 @ Newegg Australia |
Case | Fractal Design Meshify C ATX Mid Tower Case | $152.00 @ Umart |
Power Supply | Thermaltake Toughpower GF1 PE 650 W 80+ Gold Certified Fully Modular ATX Power Supply | $159.00 @ Computer Alliance |
Prices include shipping, taxes, rebates, and discounts | ||
Total | $2289.10 | |
Generated by PCPartPicker 2020-05-12 19:09 AEST+1000 |
