i had a cheap fan in my case that went out recently so i bought two new 3 pin fans one to replace the faulty one and one to replace the one beside it. after trying to change the settings in the bios i can't seem get them to go above 500 rpms.
under hardware monitor i have the ability to change the fan 1 and 2 between 50% and 100% but it doesn't effect the rpms at all.
i have another one of these fans hooked up as a cpu fan and its at about 1500 rpms when i'm looking inside the bios.
i was reading a moment ago that because its not 4 pin you can't change the fan speed that way. i'm trying to figure out if there is anyway to change the fan speed through some other means.
