Need help with fans in build
Sarutobi0997
248
Im planning on building http://pcpartpicker.com/p/xG0T and im wondering if my PSU has ports for the front panel case fans i want to use or if i have to buy an adapter and if so which adapter should i get? also are these 2 120mm fans and the 1 80mm fan in the back enough to cool my case?
Links:
PSU: http://www.corsair.com/builder-series-cx500-v2-80plus-certified-power-supply.html
Fans: http://www.newegg.com/Product/Product.aspx?Item=N82E16835103022
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811553003
The fans have 3-pin connectors built to be plugged into a fan controller or the motherboard.
If you need an adapter because your motherboard doesn't have enough connectors - you'll be looking at a '3-pin to molex' adapter. (fan -> 3-pin -> molex -> psu)
Cooling should be sufficient.
would this be what im looking for?: http://www.newegg.com/Product/Product.aspx?Item=N82E16812200855
and if it is, how many do i need?
