Need help with finding a new mobo for my i5-6600k
RachokingzOz
129
I got this cpu few years ago and didn't really have enough money for a motherboard back then. Now i saved enough money to upgrade, but not sure which motherboard should I go for. My budget is anything under $200. If possible I would like it to be around $150. Would it be better to get a z170 or z270.
Really can't go wrong with either.
Without any other information, pick out any you like with the appropriate chipset.
Size? ATX/MicroATX/ITX
Color? RGB?
Features?
Most motherboards you are after are going to be around $150, I would avoid Z boards that are closer to $100 as they generally don't have as good of an audio processor.
ahh I mean I can also just upgrade the whole thing, but if I can find a mobo that works might as well keep it.
Yea, I know it is sorta old. What should I go for if i plan to do a full cpu and mobo upgrade. Since I saved up some money now I can actually buy something like this 😛
