Need help with finding compatible motherboard
Jayblipbrp
12
I have recently bought a Gainward GTX 970 as an upgrade from an Asus GTX 650, but with the new card I don't get past the BIOS when i boot. According to a previous thread, it's because the motherboard is so old that even the newest version of the BIOS doesn't recognize the new card. I need help with finding a motherboard that will be compatible with these parts:
(Current mobo: HP Pro 3400 MT)
CPU: i5 2300 @ 2.8GHz
GPU: Gainward GTX 970 4GB (Current: Asus GTX 650 2GB)
Memory: 2x4 Corsair ValueSelect @ 1333MHz
Disk: Seagate Barracuda 500GB
PSU: Corsair B600 600W
Does anyone have a suggestion? Any help at all is appreciated, tell me if i missed any nescessary information.
you need an lga 1155 socket mobo
PCPartPicker part list: http://pcpartpicker.com/p/ZNy8TW
Price breakdown by merchant: http://pcpartpicker.com/p/ZNy8TW/by_merchant/
Motherboard: ASRock Z77 Extreme4 ATX LGA1155 Motherboard ($128.99 @ SuperBiiz)
Total: $128.99
Generated by PCPartPicker 2015-01-04 07:41 EST-0500
but do not forget ...the z77 board and the lga 1150 ...getting old and not futur proof at all
i suggest you to buy a lga 1150 mobo with a 1150 cpu haswell refresh
Seems promising, however the CPU is not my main concern, will the 970 be compatible wih this mobo?
