Need help with first build
porkchop_59
16
He guys, I'm wanting to get into PC gaming, and I need help with a build. I want to be able to play pretty much any game on high if possible for my budget, which will be 650-750. I wouldn't mind staying on the lower end of those number but if I can that's fine. I have found a case that I would like because I am going off to college, it is the bitfenix prodigy. Help with my build please.
porkchop_59
16
Yes. Do you know how well this will run BF3 or something along those lines? Also I asked this at another site and one guy posted something with a similar PSU, but then one guy commented and said that that PSU could possibly not be strong enough. What is you opinion on that??
TimeLass
451
49
you will get 45-55 FPS on high settings(not stable) and no i don't think that the PSU with 550W will not be strong enough to power up the system...
http://www.amd.com/US/PRODUCTS/DESKTOP/GRAPHICS/7000/7850/Pages/radeon-7850.aspx#2
that PSU will be fine but you won't be able to fit the 7850 without taking out the 3.5 inch bay and I would avoid the steagate 7200.12AS drives and spend up for either the caviar blue 64mb or the seagate 7200.14 64mb
Swap out the 3.5inch drive for a 2.5inch one if you want to keep the same case
CPU: Intel Core i5-3470 3.2GHz Quad-Core Processor ($188.79 @ Amazon)
Motherboard: Gigabyte GA-H77N-WIFI Mini ITX LGA1155 Motherboard ($98.24 @ Amazon)
Memory: Corsair 8GB (2 x 4GB) DDR3-1600 Memory ($39.00 @ Amazon)
Storage: Seagate Momentus 750GB 2.5" 7200RPM Internal Hard Drive ($64.99 @ Amazon)
Video Card: XFX Radeon HD 7850 2GB Video Card ($169.99 @ Newegg)
Case: BitFenix Prodigy (Orange) Mini ITX Tower Case ($89.98 @ Outlet PC)
Power Supply: Corsair Builder 430W 80 PLUS Bronze Certified ATX12V Power Supply ($34.99 @ Newegg)
Total: $685.98
(Generated by PCPartPicker 2013-02-24 01:18 EST-0500)
Here is one with a hybrid Momentus XT drive that combines a 8GB NAND cache with 750GB of HDD
Storage: Seagate Momentus XT 750GB 2.5" 7200RPM Internal Hard Drive ($129.99 @ Dell Small Business)
Total: $750.98
(Generated by PCPartPicker 2013-02-24 01:19 EST-0500)
review of the XT drive
http://www.tomshardware.com/reviews/momentus-xt-750gb-review,3223.html
http://www.anandtech.com/show/5160/seagate-2nd-generation-momentus-xt-750gb-hybrid-hdd-review
TimeLass
451
49
agree with wat you said... i put that in because he choose that case... and also that case is a very good one for ITX build IMHO... well Lian-Li is will be good too :sweat:
porkchop_59
16
Also would you all consider the AFX Radeon that both of you listed as a better GPU than GIGABYTE GV-R785OC-1GD Radeon HD 7850 1GB? I have read a lot of good things about the Gigabyte.
The gigabyte has a better cooler and has a factory OC and you get all that for $15 more than the stock xfx 2GB which is a pretty decent as you want the best cooling you can get in such a small case
Are you planning to take out the top 3.5inch HDD bay then?
Upon further research it appears you can fit 3.5inch drives in the bottom drive cage
porkchop_59
16
Yeah, I was thinking about it. I want to try and get the most performance as I can for my budget. I have read it doesn't do a lot if I take it out, I can live with only 500GB. I already have a 1TB external drive that I use to store movies on for my Laptop and I still have well over 750GB available on it.
TimeLass
451
49
Take 500GB will be good enough then... You can always add in another HDD or SSD in the future... :bounce:
Similar threads
