hi, this is my first PC build
https://pcpartpicker.com/user/Jowyhxj/saved/CHnL23
first PC build, no signal from monitor.
ATX, ATX 12 V cable both are connected, CPU fan is running.
start with 2 ram stick, but also try with 1 ram stick only.
after i try to replug and reconnect the GPU(Rx 570) and the Cable, the GPU fan stop running and still no signal.
is there anything i done wrong, or i just got a Bad graphic card? everything are new buy, not used.
any help please.
any help please.
