So i recently ordered all the parts for my first ever pc build. I've never built a pc before so i might have made a single mistake which i noticed like 10 min. ago.
The GPU that i ordered is Evga gtx 1060 sc gaming, while the motherboard is asrock h110m hds.
I noticed on the gpu requirements tab that it requires a 6pin power connector, however i don't think the motherboard has a 6 pin.
I honestly totally overlooked the details because i was camping for availability and wanted to order the gpu as fast as possible.
Can you help me and tell me if there is going to be any problem with this GPU and that mobo an if yes, which other motherboard would be good ? Also any other incompatibilities ? I checked on pcpartpicker, and there was no problem, but i am still not sure if the motherboard has everything necessary.
I am still waiting for a confirmation call about the parts so i can still change the mobo with a different one.
Here's a full list of the parts :
1x INTEL CORE i5-6500, 3.20GHz, 6MB, BOX, LGA1151, Skylake
1x NZXT S340, Midtower, Black + Blue
2x KINGSTON 8GB DDR4 2133MHz, CL15
1x SAMSUNG 120GB 2.5" Solid State Drive 750 EVO /SSD/, SATA III
1x COOLER MASTER G550M, Bronze, Modular
1x TOSHIBA 1000GB 7200rpm 32MB SATA III, DT01ACA100
1x ASROCK H110M-HDS, H110, DDR4 2133, DVI, HDMI, LGA1151
1x EVGA 6144M GTX1060 SC GAMING DDR5 PCI-E3.0
2x NZXT Fan 140mm, RF-FZ140-02
