Lol? What?Be smart, always buy phones with detachable cables. Phone cables WILL BREAK with usage, is a given.
Can you take pictures and upload to image hosting site then link it here?
Cause some cables are together with rope and coated with paint and you have to burn them to remove that.
i am wondering how you bent the audio plug..... 😀
you can get new cables cheap
https://www.ebay.com/i/272957807285?chn=ps
i remember the good old days of rewiring my KOSS headphones as a kid, had a large family using them all the time so the wires often broke, I just wired them up with heavy wire every few months.
Lol? What?
Yes, exactly as Ive said, you can strip it down with knife or with scissors .
Lol? What?
Yes, exactly as Ive said, you can strip it down with knife or with scissors.
You "may" try burning down with lighter but you may burn the copper.
Try to sand paper it? Or do similar with knife or scissors or solder onto it (which is way easier)
Lol? What?
