Hi!
I have had a problem with my asus P5K mobo for quite some time.
Usually I got the BSOD saying the IRQL_NOT_QUAL_OR_LESS. With a lot of testing and reinstalls I located that the built in soundcard was the culprit, deactivating it caused the problem to vanish.
So I bought a new sound card, and it has helped but not entirely, as the random BSODs still pop up from time to time (but not as often) I get two different BSODs, one with the irql not equal or less, and one that just states that it has dumped the physical memory, only once did I get one with a driver stated ks.sys
However I was told that freeing up IRQ by disabling devices in the BIOS has helped, so I've already disabled the soundcard and the floppy. So I'm asking you to tell me what more I can disable.
My hardware configuration is as follows:
MOBO: Asus P5K, P35, Socket-775, DDR2,
HDD: Samsung SpinPoint T166 500GB SATA2
CPU: Intel Core 2 Quad Q6600 2.4GHz
RAM: Corsair TWIN2X 6400 DDR2, 2048MB CL5
Graphic card: XFX GeForce 8800GTS 500M 640MB GDDR3, PCI-Express, 2xDVI/HDTV/HDCP, 320-bit
Samsung DVD +/- RW
OS: XP Pro, SP2
Thanks for any help in advance.
ps. Yes I have the latest drivers for the hardware installed.
Samsung DVD +/- RW
OS: XP Pro, SP2
