Need help with front io panel cables
christapia54
13
I have a new case and was going to install in new motherboard but doesnt work so i will use the old one that came with the pre built pc i bought but the motherboard doesnt have a manual for me to plug in the panel connections so im out of luck if someone could help me install them id appreciate it also the motherboard came from this pc
https://www.amazon.com/G11CD-US006T-Gaming-Desktop-Nvidia-GTX980/dp/B016E80LF0
The panel connectors have
POWER SW +-
RESET SW+-
POWER LED -
Power led +
H.D.DLED +-
Trial and error.
There is only one set that you truly need, namely the power switch.
The pwr switch is a momentary switch that is not polarity sensitive.
Connect one lead to what you might guess is a ground pin, then try adjacent pins and see if it powers up.
If you get it wrong, nothing bad will happen.
Trial and error.
Isn't the motherboard model printed on the PCB?
I think those models from Asus have some variant of the Asus H110 motherboards.
