Need help with front panel audio wiring
chichi2237
Hi so recently I had my mobo and cpu changed for me and my front panel audio jacks weren't working, I had tried every software based solution and now I decided to open the case and see if the headers are connected and wouldn't you know it - none of the 7 were 😀 Unfortunately my mobo's manual isn't clear to where the headers should go, or atleast I can't understand it. Here is a link to the manual (on page 1-21):
http://www.asus.com/Motherboards/P8H61M/#support_Download
and below I'll tell you guys what's on the connectors and their corresponding colour:
GROUND - BLACK (ok this one is pretty obvious but the others aren't)
MIC IN - PINK
MICBIAS - YELLOW
SPKOUTL - WHITE
RETURNR - GREY
SPKOUTR - GREEN
RETURNL - BLUE
I found this on the internet:
http://www.tehnari.ru/attachments/f99/118430d1359172314-hd_audio_pin.jpg
It seems plausible, doesn't it? Apparently my front panel audio is AC97, my manual says the mobo supports both ac97 and hd audio so I guess that's not a problem (or is it?), so I'm guessing my GROUND goes to pin2, MIC IN goes into 1, MICBIAS - 3, SPKOUTL - 9, RETURNL - 10, SPKOUTR - 5, RETURNR - 6?
Edit - I found another image basically stating the same thing:
http://img.techpowerup.org/111213/Capture026.jpg
But still can someone who knows more about this than I do tell me to go for it?
PS: My audio is via hd, not realtek, so suggesting to disable front panel detection won't work for me.
