Need Help With Front Panel Connectors! (Power SW + Reset SW)
FallingFist
5
Okay, so today I built my first rig.
Everything, and I mean everything, is working just fine.
Everything, except the power switch and the reset switch.
The 2-pin connectors are plugged in correctly, and I've even tried both ways.
Shorting the pins with a screwdriver actually works flawlessly, but I don't want to open my case every time I'm booting my computer up.
Case is the Zalman Z9
http://www.newegg.com/Product/Product.aspx?Item=N82E16811235027
MoBo is Asus F2A85-V with FM2 Socket
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131937
I really need help with this. Anything from tips to possible solutions are fine.
Will post pictures if necessary.
Thank you!
EDIT *Fixed USB ports*
It's possible that you have bad front panel switches or wiring. If you have verified your connections (they should be shown in your motherboard manual) your best bet would to contact wherever you bought the case from and RMA it to get a new one (if it is still in their replacement warranty period) or contact the case manufacturer to see if they will send you a replacement part.
