Need Help With fx9590
gogman25
9
So its taken a long while and a lot of parts, so i will try to keep this punctual. Had a sabertooth v.1, had to replace my fx 4170, closest i could get to replace was the monstrous 9590. Stabilised it with a coolermaster 212 evo and disabling 4/8 corssand getting a corsair cx750m to power it. Recently upgraded with a Crosshair V formula Z, 2x8gb fury 1866 ram sticks. I am now getting peculiar freezes. E.g whilst I've got say Steam and skype open, I'll open maybe Chrome and it freezes to the point of needing a hard reset. So no dice. For easy reference I'm currently using 2x hyperx fury 8gb ram (new) at 1866mhz, amd fx9590 4.7ghz, crosshair v formula z (latest version)n hyper 212 evo cooler (managed it at full load but going to go for a big old noctua just for good measure.). I apoligise about the format but this is phone posted for obvious reasons. My plan of action at this point is a noctua, couple of extra case fans, and a 1000w psu just for good measure. However, with the freezing it means anything other than a bios temp check is impossible, and forget a memtest. Any ideas or at least confirmation of my own? EDIT: attempted my old 4 cores trick and im seeing immensely improved stability. Heat is drastically lower too. With that being said, cpu issue, psu issue, or heat issue, whats the best bet? Mega edit: tried at 6/8 cores and stable under stress test, only freezing after a long period of time. In short, more cores, quicker freeze. Thats the conclusion, thoughts?
Bios is all updated. It did improve stability but ultimately still unstable by a large margin.
