Need Help With Gaming Computer Hardware.
Rob_Gamin
13
Im currently building a budget gaming PC and im wondering if all of the parts that i have chosen will work together without having to do any extra bio updates etc. I have a GIGABYTE GA-B250M-DS3H LGA1151 Intel Micro ATX DDR4 Motherboard with Intel Pentium G4600 3.6 LGA 1151 GHz Dual-Core Desktop Processor and Ballistix Sport LT 8GB Kit (4GBx2) DDR4 2400 MT/s with a Gigabyte GTX 1050 Ti Windforce OC 4GB GDDR5 128-bit PCI-E Graphic Card.
the bios update would be to support the cpu?
afik that motherboard will not need it to use that cpu
look viable to me, i would proceed with the build, especially if the cpu can be found at a decent price
Ok, thank you i was just making sure that i wouldn't need to do any extra work when its all put together and if all the parts will work well together.
