Need help with Gaming PC!
Matt-I
6
Looking to spend £600 on a Gaming PC.
Need everything from CPU to PSU to a case. Don't need keyboard/mouse.
Minimum 8GB Ram.
Looking to spend £150 on GPU, already got a CPU in mind , then £100 on Windows 10 if needed.
Found this Processor already:
http://www.aria.co.uk/Products/Components/Processors/AMD+CPUs/FX+%28Piledriver%29+-+Socket+AM3%2B/AMD+FX-6350+Unlocked+Six+Core+Processor+3.90GHz+%284.20GHz+Turbo%29+?productId=55427
Total Budget is around £600
Don't need a CPU unless you can recommend a better one
8GB RAM minimum
Thanks in advance c:
Not the best GPU, but it's workable for a while, and gives you a solid CPU foundation, on the latest platform.
CPU: Intel Core i5-6600 3.3GHz Quad-Core Processor (£155.00 @ Amazon UK)
Motherboard: Asus Z170M-PLUS Micro ATX LGA1151 Motherboard (£84.46 @ Amazon UK)
Memory: Crucial 8GB (2 x 4GB) DDR4-2133 Memory (£33.99 @ Ebuyer)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£57.25 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£29.99 @ Aria PC)
Video Card: Zotac GeForce GTX 750 Ti 2GB Video Card (£86.99 @ Ebuyer)
Case:...
Sorry, just making sure I'm understanding.... 600 is your budget, including the OS (~100) and GPU?
If you want this rig to be upgradeable, you should really be looking at Intel rather than AMD. They will have new sockets soon, and some (most/all?) of their sockets are "dead". AM3, FM2, FM2+ won't be seeing any new chips.
That's not a knock on AMD, I have an Athlon 860k and I really like it. It does the job for me. Just somehting to be mindful of.
Are you looking for an ATX build? mATX? Mini-ITX?
Case: Cooler Master N200 MicroATX Mid Tower Case (£37.67 @ Amazon UK)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply (£41.45 @ Amazon UK)
Operating System: Microsoft Windows 10 Home OEM (64-bit) (£72.30 @ CCL Computers)
Total: £599.10
Generated by PCPartPicker 2015-12-15 22:47 GMT+0000
For another 70quid or so, you could have a GTX 960 4GB, which would give you a well-rounded rig.
Video Card: Gigabyte GeForce GTX 960 4GB Video Card (£156.98 @ Novatech)
Total: £156.98
Generated by PCPartPicker 2015-12-15 22:49 GMT+0000
