Need help with Gaming/work build - about 4500 eur
NearlyPerfect
22
Hello! I'm looking for the best PC build for gaming and work. I still haven't decided what size monitor (it will be 4K res) I want so I'm looking only for a configuration for about 4500 eur. I'm from Bulgaria so please suggest stores which deliver here.
I'd like to run GTA V on max details 4K/60fps. Oculus rift too (shouldn't be a problem). Switching between a hundred tabs in Chrome should be slick too. Also using sandboxie with 20 isolated Chromes each with a few tabs.
I really prefer: Intel, Nvidia, Kingston and well known brands for the other components. 64 GB RAM DDR4.
1: cheaper
1.5: which means better price to performance ratio
2: overally better cooling
3: higher overclocking capability
3.5 which results in higher performance
Edit: EVGA GeForce GTX 980 Ti 6GB K|NGP|N ACX 2.0+ is also good choice instead of the Zotac AMP!. Zotac just is slightly cheaper and higher out-of-the-box clocks.
Well, I have no idea about the stores, but here's a rough draft of what you could get:
i7 5960x
any great high-performance air cooler
X99 motherboard with as good SLI capability as you can find
DDR4 2800Mhz
2x GTX 980TI. For example, the new Asus ROG Matrix GTX 980Ti Platinum which is a beast out of the box and will overclock even further.
Tier 1 Platinum or Gold 850-950W PSU from here: http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
Sorry that I can't provide any better information of prices and stores.
But couldn't find any pages which I would understand something out of.
So PCPartPicker don't have a bulgarian option, so I did it in German to get Euros, but fi you go to Amazon then you should be able to get it all.
I left spare money for a monitor, an extra graphics card or an upgrade tp the 5960X
PCPartPicker part list: http://de.pcpartpicker.com/p/CWcCxr
Price breakdown by merchant: http://de.pcpartpicker.com/p/CWcCxr/by_merchant/
CPU: Intel Core i7-5930K 3.5GHz 6-Core Processor (€590.68 @ Mindfactory)
CPU Cooler: Corsair H100i GTX 70.7 CFM Liquid CPU Cooler (€123.46 @ Mindfactory)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard (€383.99 @ Amazon Deutschland)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory (€228.65 @ Mindfactory)
Memory: Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-2666 Memory (€109.92 @ Mindfactory)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive (€173.43 @ Mindfactory)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive (€98.00 @ Mindfactory)
Video Card: Gigabyte GeForce GTX 980 Ti 6GB Video Card (2-Way SLI) (€686.77 @ Mindfactory)
Case: Lian-Li PC-O8WX ATX Mid Tower Case (€587.38 @ Amazon Deutschland)
Power Supply: Corsair Professional 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply (€247.40 @ Mindfactory)
Total: €3916.45
Generated by PCPartPicker 2015-10-22 18:58 CEST+0200
Get 980Ti instead of Titan X.
1600W PSU is overkill.
You will only need maximum 1200W.
Get an PCI-E SSD instead if you are going that much overboard.
http://pcpartpicker.com/p/zHsJLk
CPU: Intel Core i7-5960X 3.0GHz 8-Core Processor ($899.99 @ Micro Center)
CPU Cooler: be quiet! Dark Rock Pro 3 67.8 CFM Fluid Dynamic Bearing CPU Cooler ($89.90 @ Newegg)
Motherboard: Asus X99-DELUXE ATX LGA2011-3 Motherboard ($386.98 @ Newegg)
Memory: Corsair Vengeance LPX 32GB (4 x 8GB) DDR4-3000 Memory ($309.99 @ Amazon)
Storage: Intel 750 Series 800GB PCI-E Solid State Drive ($699.99 @ Newegg)
Storage: Seagate Barracuda 3TB 3.5" 7200RPM Internal Hard Drive ($85.35 @ Amazon)
Video Card: Zotac GeForce GTX 980 Ti 6GB AMP! Extreme Video Card (2-Way SLI) ($669.99 @ B&H)
Case: NZXT Phantom 820 (Black) ATX Full Tower Case ($206.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA P2 1200W 80+ Platinum Certified Fully-Modular ATX Power Supply ($235.99 @ SuperBiiz)
Optical Drive: LG WH16NS40 Blu-Ray/DVD/CD Writer ($52.89 @ OutletPC)
Total: $4618.04
Generated by PCPartPicker 2015-10-23 11:40 EDT-0400
1: cheaper
