Need help with gpu choice
troy69x
4
my question is whats stronger? Gtx 460 or Gtx 560? I am guessing 560 but better get it confirmed to be safe. Is there really any difference? considering my biggest monitor goes to 1440x900.Though i prob use my smaller one. 1280x720. Is it safe to say either would be strong enough to play most games out atm on those resolutions?
iGGY-101
50
560 is a bit better than the 460, i have a 560ti which is even better than the 560 and it runs pretty much all games on max w/ 1920 x 1080 resolution. If you can get the 560 or 560ti, But if you are tight on budget a 460 is amazing.
