Need help with GPU (GPU Upgrade)
mB_ilusion
Hello
My gpu died yesterday, I was using a AMD 6770 1gb DDR5 (PCI Express 2.1 x16), on a low end gaming pc. Now I need help to buy a new one. I only play games like CSgo, H1z1, etc... so the gpu that I was using worked pretty well for my needs (but of course was a bit old). So im looking for a gpu similar to the one that I was using, low budget (around 100€, or less if possible), and with DVI-D (if available, not really a must). Any suggestions are welcome.
Thanks in advance
If you're only using your card for games like that I'd go used and get something cheap. The rx 460 is good but that 150 dollar version is just stupid. For 150 you could get a gtx 970 which is overkill for csgo. Now h1z1 that's different. I think the perfect option here is to go with a gtx 660ti which will give you pretty good performance for your buck, but never get a new graphics card under a $100 because it's most likely a piece of dog s$&@.
