Need help with gpu
G
I've been using the 320W PSU of my prebuilt HP for a couple of years now, with a GTX750. Yes it works fine. I've seen no problems ever. And these 1050 cards are similar to the 750 in power consumption.
But i still recommend a newer PSU before getting a new GPU.
It's just that we don't want to take any risks, now do we?
You'll be pushing the limits with that.
It is highly recommended that you change the PSU to something better quality and 400+ watts.
I think it'll work. By that I mean if it was my computer I'd do it. I would however set aside money as soon as possible to upgrade the PSU next. By that I mean I wouldn't just add the videocard and forget about it. The reason is while I think that PSU is powerful enough, I don't trust the quality, how long it'll last. This depends on how you're going to use it too. If you're going to be running demanding games all day, you'll put a lot more load on that PSU than if you don't game all that much every day.
