Need help with Graphics Card & PSU
Haxorus
Im looking to upgrade my PC, Preferably the Graphics card, My Specs are as followed,
CPU
AMD A10-5700
Trinity 32nm Technology
RAM
7.00 GB Dual Channel DDR3 @ 798MHz (11-11-12-28)
Motherboard
MEDION MS-7800
Graphics
SMS22A100 (1650X1050@60Hz)
523MB ATI AMD Padeaon HD 7660D (MSI)
Storage
931GB Seagate STI1000DM003-9YN162 (SATA)
232GB Seagate ST925082 7AS USB Device (USB (SATA))
Optical Drives
TSSTcrop CDDVDW SH-216AB SATA CdRom Device
PSU
FSP450-60EMDN
AC INPUT:230-240V
DC OUTPUT:450W
For upgrading/building a PC go here: http://pcpartpicker.com/
It will alert you of any incompatibilities with your hardware.
What are you looking to do with your PC? If gaming, what games and what quality are you looking to play?
Average gaming, Looking to play CSGO with around at least 100-200 FPS, also looking to be able to play a game Called "The Forest" at Medium Settings.
If you can I would recommend upgrading your CPU. I highly recommend Intel rather than AMD, but because you have an AMD CPU that probably means your motherboard isn't compatible with Intel.
If you don't want to get a new build then upgrade to a quad-core CPU that is compatible with your hardware.
You will probably need some more power also so you probably want to get a new PSU as well.
CSGO and the forest at med specs (or higher) does not require a beefy computer so you shouldn't need pricy parts.
What is your budget?
Not too sure, But as anyone eles would say, If its cheap, and can get the job done, Ill take it.
Sorry for the double post, But could you give me some information on which Quad Core CPU i should get that is compatible with the rest of my PC?
