Need help with Graphics cards
toadie
I don't know anything about graphics cards, and I need a good one for my graphic design program. I found the 13in, macbook pro with the geforce 320m but don't know anything about it. If you can tell me if it will be a decent card or if i should save up longer for the 330 gt instead. Thanks
toadie
I'm looking to have the mac hooked up to a larger monitor at home so the screen size is not an issue, and the hard drive capacity is no issue either. I can upgrade the ram to 8 gigs.
another thing I would like to know is a good place to buy it, whether the apple store is a good place or not...
