Need Help With Hard Drive Configuration
Jul 23, 2018
21
Hello to everyone!
I would like to do 1080, AVCHD/MP4, h.264 Video Editing
I would also like to do Audio Recording
I would also like to do 2D cartooning
I'm confused on how I should set the drives up for a good, smart, efficient, way to work with these programs?
Plus what type of drive I should use and why? ( Reason, Size, Speed, etc... for each program/software?)
Below is my computer hardware and software I would be using.
Many thanks to all in advance with input, it is deeply appreciated!!!
Computer Build Stuff:
Drives Available:
2 x 1TB WD Blacks HDD's
2 x 4TB WD Blacks HDD's
4 x 500GB WD Blacks HDD's
3 x 250GB Samsung 850 EVO SSD's
3 x 500GB Samsung 850 EVO SSD's
CPU = i7 6850K, 6-Core, Base Clock 3.6 Ghz
Heat Sink/Fan = Hans Reeven
MOBO = MSI X99A SLI
RAM = 32GB DDR4 2133
GPU = MSI 1070 8GB Vram
PSU = 1000W Ultra X3 Single 12v Rail Bronze
Case = Fractal Design R5
PCIe Firewire Card (For Audio Interface)
Card Reader (SanDisk ImageMate Pro Multi Card Reader/Writer)
2 x Asus 1920x1080 VK264H Monitors
Mouse
Keyboard
Software:
OS, Which should I use? = W7 Ultimate Retail or W8.1 Pro OEM
(W10 is incompatible with the Interface)
Audio Software = Presonus Studio One Pro V3.0
Video Software = Cyberilnk PowerDirector 16
Cartoon Software = MOHO Pro 12
Sample Library = Stock Presonus as of right now, but more will be added later
First Windowsd 8.1 pro simply because WIN 7 is out of support in 2020
Next youve gone a bit crazy with the drive selection 😀
its better to have all the same size cause then you could use Raid effectively. But you cant due to the mixed bag. (if youve already bought them)
IF not well first i would RAID 1 the two 4TB drives as well as the 2 500 GB SDD, you would have the resiency in both setup and your HDD for big storage with your SSD for quick and fast storage.
In an ideal world you would Buy 4 2-3 TB drive and build a Raid 10 that would give you significant resiliency and performanence pluses, aroung 6TB usable andthen i would soft partition the Array Ibasically partition the drive in windows) (also very quick rebuild times). and...
In an ideal world you would Buy 4 2-3 TB drive and build a Raid 10 that would give you significant resiliency and performanence pluses, aroung 6TB usable andthen i would soft partition the Array Ibasically partition the drive in windows) (also very quick rebuild times). and just use a small SSD for your OS.
I woullg change a few bits and pieces though.
1. PSU doesnt need to be so big and, i would reduce wattage and increase quality
2. 8th GEN i7 now offer SIX core which is something to really look into especially as its brand new.
3.maybe just me but maybe look into higher RES monitors increassed productivity (more screen space)
These are just suggestions of improvements.
