Question Need help with HD60 pro
Jun 19, 2019
6
I have 1 pc and I use it for gaming. Except I wanted something so I can make clips, so I bought the HD60 pro which is a pci version. I’m not sure how to actually get footage off of my monitor that I game on. I figured if I plugged it into my pc I would have hot keys that I press to clip things, although I believe it’s a little more complicated than that. Any help would be greatly appreciated. Thanks!
feed hdmi from gpu to the hd60, then hdmi from that to your moitor. it has two hdmi for a reason. they must have captuer software that comes with it. get the software you need here:
https://www.elgato.com/en/gaming/downloads
That’s what I tried but when’s i do that it basically powers a second monitor but on 1 monitor. My vga input is my main monitor and my hdmi input is my second monitor. With the HD60 pro there no way to choose what actually is displayed on the software. Kind of like how you can choose what monitor you want on OBS, it doesn’t do that.
