I have a hard drive (WD3200AAKS) with Windows7, NTFS, which was used internally. To install Linux Zorin for a dual system, I successfully resized the existing partition and allocated sufficient space to accommodate the new OS. I do not remember which disk utility I used for that. At some point I was asked to determine where the paging (?) file location should be and what size. According to some information online, it could not be on the same partition as the new OS, and one of the tips was to choose the windows partition for it, which I did - and have been since unable to open anything on that HD with any disk/partition utility in another Linux or Windows system.
When I connect it externally via USB, my Linux (and WinXP) system detects it correctly as "320 GB Hard Disk: PavilionWin7 Local Disk". Its properties are given as PavilionWin7 Local Disk, Type:folder (inode/directory), Contents: nothing. Yet from total capacity of 320 GB it shows 217 GB free and 103 GB used. So I figure all the data is still there somewhere.
The Ubuntu (Zorin) disk utility tells me, among others, the Partition Type: HPFS/NTFS (0x07) and also checking the filesystem produces error detail "Device is mounted and no online capability in fsck tool for file system".
GParted shows it as NTFS, 298GB size, used 96 GB and unused 202 GB,flag: boot. Unallocated partition 1.34 GB.
I have not tried a Linux Live CD to see if I can access the data.
Can this be fixed? I mean to save the data at least, if not the Win7 install. Because when I open it now, there is nothing - blank, white page with "no content".
I would be greatful for any help with this, many thanks in advance.
