[SOLVED] need help with headset
rezaka16
140
5
595
Hey. Basically I'm noticing that my headset's quieter since a few days. Any tips on how to return it back to normal?
Make and model of your headset and how you're connected to your sound card? What OS are you running and if it's Windows 10, include the version you're currently on. Best to also check and see the version for your BIOS for your motherboard.
Lastly, try uninstalling and reinstalling your audio drivers, if the headset you're using is analog.
