APPROXIMATE PURCHASE DATE: Over the summer BUDGET RANGE: $1300-$1500 After Rebates
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Gaming, surfing the internet, school work, watching movies
PARTS NOT REQUIRED: Keyboard, mouse, monitor, speakers, case (Full Tower)
PREFERRED WEBSITE(S) FOR PARTS: newegg.com
PARTS PREFERENCES: i5, EVGA gtx 400 series gpu, Asus motherboard, Corsair modular Powersupply, DX 11 graphics card
OVERCLOCKING: Maybe SLI OR CROSSFIRE: No
MONITOR RESOLUTION: 1920x1200
ADDITIONAL COMMENTS: I would like this computer to play most current games at around 30fps. I don't want the computer to be very loud, but it does not have to be silent. Since I will not be doing any overclocking at first, I will stick with the stock cpu cooler that comes with the cpu and then later upgrade to a hyper 212+ or a Corsair h50.
Asus Maximus III Formula/i5 750 combo
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.369226
CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CMP4GX3M2A1600C8
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145297
EVGA 012-P3-1472-AR GeForce GTX 470 (Fermi) SuperClocked 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130549&cm_re=evga_gtx_470-_-14-130-549-_-Product
CORSAIR HX Series CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139011&Tpk=hx850
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
Pioneer Black 22X DVD+R 8X DVD+RW 12X DVD+R DL 22X DVD-R 6X DVD-RW 12X DVD-RAM 40X CD-R 32X CD-RW 2MB Cache SATA CD/DVD Burner LabelFlash Support - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827129045
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116754
The total is $1326.93 without shipping and rebates.
Please Post your idea, comments, and suggestion/changes for this build
