Need help with identification of connector type (USB) for storage unit
kataka
Dear all,
I am searching for the correct type of USB-cable but I'm unable to identify it. I've tried several versions (standard Mini/Micro-USB an some others) but none 'fit'.
The connector is for a memory unit which I believe is ment for a camera. Unfortunately I can not identify any kind of brand on it. An image of the connection from some angles and together with a standard micro-USB can be seen here:
http://tinypic.com/r/2hzlngk/8
Any help at all or direction to some site which can help me identify this would be much appreciated.
Thank you
As I mentioned in the original post it is not a micro USB, it is much narrower. About 2/3 as wide as the micro USB and also higher. I suspect it might be some brand-specific connector...
But thanks anyway!
Hard to tell without the scale. Some cameras use a propietary connector.
