need help with information on my gpu R7-M340!
kfclovermlgboi
previously known as the Radeon R5 AND R7-M340, but now changed to amd radeon r5 graphics, i can't tell if this is dedicated or integrated because i also run an amd cpu, also need help deciding on a gpu less than 90 dollars
What are you asking? If you are wanting to upgrade your GPU, honestly, don't even try. Your graphics card is probably soldered onto the motherboard, and even if it isn't, it would be very expensive to replace it.
i see. if this isn't integrated, what graphics card would you reccommend for a laptop, as most desktop gpus won't fit
