Need help with internet
DMTron
191
So I moved into a new house, got a new router and new internet provider. My computer is connected to the router through the cable while all the phones and laptops are through wifi. Everything worked for a week and no nothing connects to wifi. Only my computer works with the cable. All the phones and laptops and xbox one, all of these cannot connect. I can see it in wifi but it is very very week and when I try to connect it connects and then disappears and connects again, but just does not work anywhere. Please help asap.
first of all make sure your router is brodcasting..on the bottom of it from the isp is it ssid name. make sure your devices can see it. use your desktop and log into the router and do a reset. then go back and reset your ssid and wep/wpa and see if the devices work. a few tips...if there are more of the same routers near by and they have the green one button set up on them when someone uses that one button set up all the same units within range cnage be changed. also they use the same admin and password name so it does not take a lot for someone to log in and change your settings if you dont change the admin and password of the router. also on the router some isp now have guest ssid you have to turn them off if your in a condo or near a min street or you have leaches.
