Need help with ITX-Motherboards and Graphics cards.
Pimpsqueak
55
Hi there, I am currently thinking of buying a Mini-ITX Motherboard for decent gaming. I am currently thinking about either the ASUS AM1I-A or the MSI AM1I.
Hoever, I don't know much about ITX-motherboards, I've just heard they are perfect for compact gaming. Here is what I need to know:
1. Do ITX-motherboards come with an already installed CPU? Because I am thinking of getting an Intel Xeon as a CPU but I'm wondering if I actually need to.
2. Will a Geforce GTX 660 Graphics Card work with either of the 2 ITX's?
3. Will a 600W PSU work with either of the ITX's? Do I even need a power supply for an ITX?
4. Will it run Windows 10? (Could go for Windows 7, but prefer Windows 10).
Im thinking of using this "Mini-Compact-Gaming-Computer" (obnoxiously long) as a LAN or Backup PC as I am currently waiting for my newer PC components, but I didn't feel like selling them for $10, so I want to know everything I can about the topic before purchasing anything "big".
Thanks in advance!
1. No, itx needs a cpu. Moreover, the motherboards you listed are for low end AMD processors and will not run intel cpu's
2. All ITX motherboards will have a single PCIE X16 graphics slot. You can run any modern graphics card made in one. GTX660 included.
3. All pc's need a psu. The wattage you need is determined by the discrete graphics card.
Here is a chart:
http://www.realhardtechx.com/index_archivos/Page362.htm
4. Any ITX motherboard will be ok with windows 7/8/10.
Here is a chart:
ITX is for extremely small cases. perfect for a video station. aka HALF HEIGHT video cards aka NOT gaming cards. A MICRO atx motherboard/case, however does have a pci-e full height slot for any video card your power supply can handle. cooling, however in a micro atx might be an issue. Mid-atx is the best choice, including a good cooling system (even if just fans)
Thanks for the help, I appreciate some feedback.
Moreover on the CPU's, do you think you could recommend some ITX-Boards that do support Intel CPU's if you know any? Will the ASUS-AM1M-A work?
Again, thanks in advance.
Latest posts
