Question Need help with Kingston HyperX Fury DDr4 hx424c15fb2/8 Best timing
kitnoman
7
So I've been using HyperX Fury dd4 for a while now, and I recommended this to my brother He's using my old Gigabyte B360m-H mobo, and as the frequency can only be set to 2666 max, I'm helping him tighten the timings, which I'm not good at. When set to auto, the the timing is 2667mhz 17-17-17-40(when xmp is on and 2400 15-15-15-35 when off) and So far here are the ones that worked when I manually set it.
2667mhz 14-16-16-35 1.2v
2667mhz 15-15-15-35 1.2v
2667mhz 15-17-17-35 1.2v
And I'm currently using 2667mhz 14-15-15-28 1.25v
Should I keep these timings or should I try another one?
HX424C15FB2/8
• JEDEC/PnP:
DDR4-2400 CL15-15-15 @1.2V
DDR4-2133 CL14-14-14 @1.2V
•XMP Profile #1:
This not 2667MHz memory, however you managed to get the PC to boot at that speed. Perhaps you listed the wrong part number.
It really is and the main selling point and advertisement of hyperx is it's auto overclocking. It's plug and play, when you turn on xmp and plug it on a mobo that can handle. You can even read it on their website
"HyperX Plug N Play is a memory overclocking concept pioneered by Kingston. Featured on the FURY and Impact memory product lines, HyperX Plug N Play is auto-overclocked memory, with presets that are configured by our engineers at the factory. There’s no need to change settings and timings manually, or select a profile. Since the profiles work at standard voltage, you can simply plug them in and they’re ready to go. Plug N Play is ideal if you have a system that doesn't allow for memory adjustments in the BIOS, or simply if you want an easy solution to get better performance from your memory. In most systems, HyperX Plug N Play will auto-overclock itself up to the maximum speed allowed by the BIOS. "
But the thing is on a ryzen cpu and mobo or my z370 mobo, it can go to 3000mhz Theirs even a video going to 3200mhz. Believe me it can, the auto over clock works, just loose and bad timings. I currently went back to 14-16-16-35 but increase to 1.3v. Here is the screenshoot btw, showing the frequency and that it is originally 2400, View: https://imgur.com/a/89UVkvn
