I'm less experience with motherboards with built-in m.2 slot. I have this Asus Prime H270m-plus motherboard with two m.2 slots. One m.2 slot says PCIE x4 and the other says PCIE x2. My question is: does all built-in m.2 slot have same speed? Or does some m.2 slot have different speed base on motherboard specs? Because I want to get the most speed out of buying a m.2 nvme hard drive. If this h270m motherboard doesn’t support fast m.2 slot, then I might think about investing in a newer motherboard like the B350 Tomahawk.
Well, let me know what you guys think. If putting a Samsung 970 nvme into this Prime H270m will give me the same speed like the B450 Tomahawk, then maybe I should just keep the Prime H270m.
https://ibb.co/GQMWv4V
