Archived from groups: rec.games.int-fiction (
More info?)
On 28 Jul 2004 09:01:25 -0700, aerospace1028@hotmail.com
(aerospace1028) wrote:
>Jacqueline H. <lumin_orb@hotmail.com> wrote in message news:<736dg0t3o1tjis186h7h16vvkh04so72k5@4ax.com>...
>> [SPOILER SPACE]
>> [SPOILERS]
>> [SPOILERS]
>> [SPOILERS]
>> [SPOILERS]
>> [SPOILERS]
>> How do I make the sandwich with the machine in the kitchen?
>There is a hint file at:
>http://emshort.home.mindspring.com/venushints.htm#escape
>consulting it says
>"Okay, corknut butter and jelly it is. How hard could this be?
>The machine is constructed of a number of components, each of which
>will do something to a piece of bread as it moves along a conveyor
>belt. Your job is
>to get two pieces of bread along the belt, with the correct contents
>on them and without any incorrect contents (such as worms, chocolate
>sauce, etc.)
>You also need to avoid mangling the bread and destroying the
>structural integrity needed for a good sandwich. Some of these
>machines are on and some are
>off, controlled by the lever on the panel.
>The silver button loads new bread onto the conveyor. Mm, bread.
>The red button resets the machine to its initial state.
>If you examine the appliances, you can work out which is controlled by
>which lever. You may want to note the correspondences.
>[Max] I can't find the wedge of lime!
>Have you tried searching the gin and tonic supply case?
>No?
>Stop reading the hints for problems you don't have, Max. There's no
>time to mess around like this! Xavia is about to invade!
>[Max] There's no corknut butter in the lineup!
>Nope, you'll have to get the tube from elsewhere.
>And then you have to get it into the machine. If only there were a
>hole in the casing.
>Which there is, after the blender activates.
>In order to get the corknut butter out of the tube, you'll need it to
>be stomped by the pressor.
>And you need to put it in the lineup immediately before the slice of
>bread, so that it will be squeezed onto said bread.
>But if the pressor activates, a slice of bread will be damaged also.
>But if you arrange it so one of the pieces got the frozen tofu worms
>dumped on it, then it'll be protected from the heat ray.
>So, for the complete walkthrough:
>SET LEVER TO 1. PUSH SILVER. Z. Z. Z. Z. PUSH RED. PUSH SILVER. SET
>LEVER TO 3. Z. SET LEVER TO 2. PUT TUBE IN BLENDER. SET LEVER TO 1. Z.
>SET LEVER TO
>4. SET LEVER TO 2. SET LEVER TO 1. SET LEVER TO 3. Z. Thank goodness
>for modern labor-saving devices, or that might have been really
>time-consuming."
>I remember having trouble with this one myself. I think I just
>decided to be doris for this one.
>good luck
Thanks! LOL, now I feel dumb; I never realized the website answered
this; I stopped reading after " What do I do with the kitchen
machinery?"
