Need Help With Minecraft!
Catalina Emens
26
So, I'm trying to install shaders, everything is going fine, until I try to turn on the shaders while playing minecraft, I get that message in a notepad file, could you be a darling and help me? I've tried changing the permissions of the .dll file and yes all my drivers are up to date, I made sure of that :3
# A fatal error has been detected by the Java Runtime Environment:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x000000001dc3a4c0, pid=24232, tid=24980
# JRE version: Java(TM) SE Runtime Environment (8.0_25-b18) (build 1.8.0_25-b18)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.25-b02 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C [ig7icd64.dll+0x8a4c0]
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
# http://bugreport.sun.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
--------------- T H R E A D ---------------
Current thread (0x00000000023e3800): JavaThread "Client thread" [_thread_in_native, id=24980, stack(0x00000000022e0000,0x00000000023e0000)]
siginfo: ExceptionCode=0xc0000005, reading address 0x0000000000000000
Registers:
RAX=0x0000000000000000, RBX=0x000000001e3eb000, RCX=0x0000000000000000, RDX=0x0000000000000000
RSP=0x00000000023d9a40, RBP=0x00000000023d9b70, RSI=0x0000000035458948, RDI=0x0000000034a64000
R8 =0x0000000000002730, R9 =0x000000000000004e, R10=0x0000000000000000, R11=0x00000000023da208
R12=0x0000000000002730, R13=0x0000000000002730, R14=0x0000000035458920, R15=0x0000000000000006
RIP=0x000000001dc3a4c0, EFLAGS=0x0000000000010206
Top of Stack: (sp=0x00000000023d9a40)
0x00000000023d9a40: 00000000c2f00000 0000000000000000
0x00000000023d9a50: bfb800e36005d000 0000000000000000
0x00000000023d9a60: 000000001e4041c0 000000001dd22cd8
0x00000000023d9a70: 000000001e3eb000 0000000035458948
0x00000000023d9a80: 00000000023d9b70 0000000000000007
0x00000000023d9a90: 0000000000000001 0000000000000007
0x00000000023d9aa0: 0000000000000007 000000001a710bb8
0x00000000023d9ab0: 0000000000000005 0000000500000007
0x00000000023d9ac0: 000000001a710b8c 000000001ef06828
0x00000000023d9ad0: 0000000000000000 00000000023da208
0x00000000023d9ae0: 000000002f820390 000000001e4041c0
0x00000000023d9af0: 00000000000092e5 0000000000000006
0x00000000023d9b00: 0000000000000040 0000000000000005
0x00000000023d9b10: 0000000000000007 000000001a710c14
0x00000000023d9b20: 0000000000000005 0000000000000034
0x00000000023d9b30: 000000001a710bc0 0000000000000007
Instructions: (pc=0x000000001dc3a4c0)
0x000000001dc3a4a0: c2 10 66 0f e7 47 f0 49 3b c2 72 e4 e9 ab 00 00
0x000000001dc3a4b0: 00 4d 85 c9 74 6c 66 66 0f 1f 84 00 00 00 00 00
0x000000001dc3a4c0: 66 0f 6f 3a 66 0f 6f 72 10 66 0f 6f 6a 20 41 ff
0x000000001dc3a4d0: c2 48 83 ef 80 41 8b c2 66 0f 6f 62 30 66 0f 6f
Register to memory mapping:
RAX=0x0000000000000000 is an unknown value
RBX=0x000000001e3eb000 is an unknown value
RCX=0x0000000000000000 is an unknown value
RDX=0x0000000000000000 is an unknown value
RSP=0x00000000023d9a40 is pointing into the stack for thread: 0x00000000023e3800
RBP=0x00000000023d9b70 is pointing into the stack for thread: 0x00000000023e3800
RSI=0x0000000035458948 is an unknown value
RDI=0x0000000034a64000 is an unknown value
R8 =0x0000000000002730 is an unknown value
R9 =0x000000000000004e is an unknown value
R10=0x0000000000000000 is an unknown value
R11=0x00000000023da208 is pointing into the stack for thread: 0x00000000023e3800
R12=0x0000000000002730 is an unknown value
R13=0x0000000000002730 is an unknown value
R14=0x0000000035458920 is an unknown value
R15=0x0000000000000006 is an unknown value
Stack: [0x00000000022e0000,0x00000000023e0000], sp=0x00000000023d9a40, free space=998k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C [ig7icd64.dll+0x172cd8]
C [ig7icd64.dll+0x21e4be]
C [ig7icd64.dll+0x64900]
C [ig7icd64.dll+0x261835]
C [ig7icd64.dll+0x896f5]
C [ig7icd64.dll+0x163589]
C [ig7icd64.dll+0x4a487c]
C [ig7icd64.dll+0x42b91c]
C [ig7icd64.dll+0x42c22c]
C 0x0000000004347594
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J 11150 org.lwjgl.opengl.GL11.nglCallLists(IIJJ)V (0 bytes) @ 0x000000000434750e [0x00000000043474c0+0x4e]
J 11956 C2 net.minecraft.client.renderer.RenderGlobal.renderSortedRenderersFast(IIID)I (439 bytes) @ 0x0000000004804a18 [0x0000000004804180+0x898]
J 11408 C1 net.minecraft.client.renderer.RenderGlobal.func_72724_a(IIID)I (628 bytes) @ 0x0000000004515634 [0x0000000004513c40+0x19f4]
J 12135 C1 net.minecraft.client.renderer.RenderGlobal.func_72719_a(Lnet/minecraft/entity/EntityLivingBase;ID)I (1691 bytes) @ 0x00000000048c7874 [0x00000000048c4760+0x3114]
J 11879 C1 net.minecraft.client.renderer.EntityRenderer.func_78471_a(FJ)V (1921 bytes) @ 0x000000000476326c [0x000000000475c760+0x6b0c]
J 11573 C1 net.minecraft.client.renderer.EntityRenderer.func_78480_b(F)V (1306 bytes) @ 0x00000000045e301c [0x00000000045dfdc0+0x325c]
J 11070 C1 net.minecraft.client.Minecraft.func_71411_J()V (773 bytes) @ 0x000000000427a104 [0x0000000004277d60+0x23a4]
j net.minecraft.client.Minecraft.func_99999_d()V+61
j net.minecraft.client.main.Main.main([Ljava/lang/String😉V+1012
v ~StubRoutines::call_stub
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object😉Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object😉Ljava/lang/Object;+100
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object😉Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object😉Ljava/lang/Object;+56
j net.minecraft.launchwrapper.Launch.launch([Ljava/lang/String😉V+664
j net.minecraft.launchwrapper.Launch.main([Ljava/lang/String😉V+8
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x00000000176bc800 JavaThread "File IO Thread" [_thread_blocked, id=24652, stack(0x000000002dfd0000,0x000000002e0d0000)]
0x00000000176bb000 JavaThread "pool-2-thread-1" [_thread_blocked, id=24540, stack(0x00000000300e0000,0x00000000301e0000)]
0x00000000176b7000 JavaThread "Netty IO #1" daemon [_thread_in_native, id=16468, stack(0x000000002e760000,0x000000002e860000)]
0x0000000016db2800 JavaThread "Netty Client IO #0" daemon [_thread_in_native, id=17596, stack(0x000000002e660000,0x000000002e760000)]
0x00000000178f8800 JavaThread "Netty IO #0" daemon [_thread_in_native, id=24284, stack(0x000000002b010000,0x000000002b110000)]
0x0000000019b1c800 JavaThread "Server thread" [_thread_blocked, id=23604, stack(0x00000000287c0000,0x00000000288c0000)]
0x000000001946a000 JavaThread "Snooper Timer" daemon [_thread_blocked, id=14884, stack(0x000000001c2a0000,0x000000001c3a0000)]
0x0000000022c4a800 JavaThread "LWJGL Timer" daemon [_thread_blocked, id=20368, stack(0x000000001c1a0000,0x000000001c2a0000)]
0x00000000183b1000 JavaThread "Thread-10" [_thread_blocked, id=22900, stack(0x00000000289c0000,0x0000000028ac0000)]
0x00000000171e7800 JavaThread "Thread-9" [_thread_blocked, id=23444, stack(0x00000000288c0000,0x00000000289c0000)]
0x000000001b341000 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=24448, stack(0x000000001be70000,0x000000001bf70000)]
0x0000000018903800 JavaThread "Timer hack thread" daemon [_thread_blocked, id=20464, stack(0x000000001bb70000,0x000000001bc70000)]
0x000000001acde800 JavaThread "Snooper Timer" daemon [_thread_blocked, id=23592, stack(0x000000001a5e0000,0x000000001a6e0000)]
0x0000000016b70800 JavaThread "Service Thread" daemon [_thread_blocked, id=24256, stack(0x0000000016f50000,0x0000000017050000)]
0x000000001620d800 JavaThread "C1 CompilerThread2" daemon [_thread_blocked, id=25448, stack(0x0000000016a50000,0x0000000016b50000)]
0x00000000161f0000 JavaThread "C2 CompilerThread1" daemon [_thread_blocked, id=24564, stack(0x0000000016950000,0x0000000016a50000)]
0x00000000161eb000 JavaThread "C2 CompilerThread0" daemon [_thread_blocked, id=23268, stack(0x0000000016850000,0x0000000016950000)]
0x00000000161e7800 JavaThread "Attach Listener" daemon [_thread_blocked, id=23688, stack(0x0000000016750000,0x0000000016850000)]
0x00000000161e6800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=15492, stack(0x0000000016650000,0x0000000016750000)]
0x00000000161e5000 JavaThread "Surrogate Locker Thread (Concurrent GC)" daemon [_thread_blocked, id=15392, stack(0x0000000016550000,0x0000000016650000)]
0x00000000161aa800 JavaThread "Finalizer" daemon [_thread_blocked, id=24888, stack(0x0000000016450000,0x0000000016550000)]
0x00000000161a3800 JavaThread "Reference Handler" daemon [_thread_blocked, id=23872, stack(0x0000000016350000,0x0000000016450000)]
=>0x00000000023e3800 JavaThread "Client thread" [_thread_in_native, id=24980, stack(0x00000000022e0000,0x00000000023e0000)]
Other Threads:
0x000000001619b000 VMThread [stack: 0x0000000016250000,0x0000000016350000] [id=24876]
0x0000000016b74000 WatcherThread [stack: 0x0000000017050000,0x0000000017150000] [id=22312]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
par new generation total 118016K, used 55303K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 46% used [0x00000000c0000000, 0x00000000c2f77fe8, 0x00000000c6680000)
from space 13056K, 51% used [0x00000000c7340000, 0x00000000c79c9f78, 0x00000000c8000000)
to space 13056K, 0% used [0x00000000c6680000, 0x00000000c6680000, 0x00000000c7340000)
concurrent mark-sweep generation total 431892K, used 245927K [0x00000000c8000000, 0x00000000e25c5000, 0x0000000100000000)
Metaspace used 57964K, capacity 58571K, committed 58752K, reserved 1101824K
class space used 7028K, capacity 7186K, committed 7296K, reserved 1048576K
Card table byte_map: [0x0000000011ca0000,0x0000000011eb0000] byte_map_base: 0x00000000116a0000
Marking Bits: (CMSBitMap*) 0x000000000243c7e8
Bits: [0x00000000124c0000, 0x00000000132c0000)
Mod Union Table: (CMSBitMap*) 0x000000000243c8a8
Bits: [0x00000000132d0000, 0x0000000013308000)
Polling page: 0x0000000002270000
CodeCache: size=245760Kb used=38476Kb max_used=38476Kb free=207283Kb
bounds [0x00000000024e0000, 0x0000000004ab0000, 0x00000000114e0000]
total_blobs=10235 nmethods=9296 adapters=849
compilation: enabled
Compilation events (10 events):
Event: 129.168 Thread 0x00000000161eb000 12421 4 net.minecraft.block.BlockStairs::func_149691_a (13 bytes)
Event: 129.169 Thread 0x00000000161eb000 nmethod 12421 0x0000000004a89cd0 code [0x0000000004a89e00, 0x0000000004a89e98]
Event: 129.201 Thread 0x000000001620d800 12422 3 sun.reflect.ClassFileAssembler:😱pc_aload_2 (24 bytes)
Event: 129.202 Thread 0x000000001620d800 nmethod 12422 0x0000000004a9d390 code [0x0000000004a9d520, 0x0000000004a9d8c8]
Event: 129.203 Thread 0x000000001620d800 12423 1 net.minecraft.block.BlockFence::func_149662_c (2 bytes)
Event: 129.203 Thread 0x000000001620d800 nmethod 12423 0x0000000004a9d0d0 code [0x0000000004a9d220, 0x0000000004a9d330]
Event: 129.210 Thread 0x000000001620d800 12424 3 mca.blocks.BlockVillagerBed::func_149686_d (2 bytes)
Event: 129.210 Thread 0x000000001620d800 nmethod 12424 0x0000000004a9cd50 code [0x0000000004a9cea0, 0x0000000004a9cff0]
Event: 129.232 Thread 0x000000001620d800 12425 3 shadersmodcore.client.Shaders::setProgramUniform1f (36 bytes)
Event: 129.234 Thread 0x000000001620d800 nmethod 12425 0x0000000004aa8b10 code [0x0000000004aa8da0, 0x0000000004aa9c38]
GC Heap History (10 events):
Event: 122.918 GC heap before
{Heap before GC invocations=85 (full 23):
par new generation total 118016K, used 114364K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 100% used [0x00000000c0000000, 0x00000000c6680000, 0x00000000c6680000)
from space 13056K, 72% used [0x00000000c6680000, 0x00000000c6faf378, 0x00000000c7340000)
to space 13056K, 0% used [0x00000000c7340000, 0x00000000c7340000, 0x00000000c8000000)
concurrent mark-sweep generation total 431892K, used 245487K [0x00000000c8000000, 0x00000000e25c5000, 0x0000000100000000)
Metaspace used 57786K, capacity 58423K, committed 58752K, reserved 1101824K
class space used 7015K, capacity 7184K, committed 7296K, reserved 1048576K
Event: 122.927 GC heap after
Heap after GC invocations=86 (full 23):
par new generation total 118016K, used 9935K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
eden space 104960K, 0% used [0x00000000c0000000, 0x00000000c0000000, 0x00000000c6680000)
from space 13056K, 76% used [0x00000000c7340000, 0x00000000c7cf3c20, 0x00000000c8000000)
concurrent mark-sweep generation total 431892K, used 245980K [0x00000000c8000000, 0x00000000e25c5000, 0x0000000100000000)
Event: 127.278 GC heap before
{Heap before GC invocations=86 (full 23):
par new generation total 118016K, used 114895K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
concurrent mark-sweep generation total 431892K, used 242111K [0x00000000c8000000, 0x00000000e25c5000, 0x0000000100000000)
Metaspace used 57924K, capacity 58559K, committed 58752K, reserved 1101824K
class space used 7026K, capacity 7184K, committed 7296K, reserved 1048576K
Event: 127.288 GC heap after
Heap after GC invocations=87 (full 23):
par new generation total 118016K, used 6948K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 53% used [0x00000000c6680000, 0x00000000c6d49030, 0x00000000c7340000)
Event: 128.052 GC heap before
{Heap before GC invocations=87 (full 23):
par new generation total 118016K, used 111908K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Metaspace used 57949K, capacity 58559K, committed 58752K, reserved 1101824K
Event: 128.057 GC heap after
Heap after GC invocations=88 (full 23):
par new generation total 118016K, used 6272K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 48% used [0x00000000c7340000, 0x00000000c7960168, 0x00000000c8000000)
Event: 128.355 GC heap before
{Heap before GC invocations=88 (full 24):
par new generation total 118016K, used 111232K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Metaspace used 57951K, capacity 58559K, committed 58752K, reserved 1101824K
Event: 128.361 GC heap after
Heap after GC invocations=89 (full 24):
par new generation total 118016K, used 7455K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
from space 13056K, 57% used [0x00000000c6680000, 0x00000000c6dc7c10, 0x00000000c7340000)
Event: 128.536 GC heap before
{Heap before GC invocations=89 (full 24):
par new generation total 118016K, used 112415K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Event: 128.542 GC heap after
Heap after GC invocations=90 (full 24):
par new generation total 118016K, used 6695K [0x00000000c0000000, 0x00000000c8000000, 0x00000000c8000000)
Deoptimization events (10 events):
Event: 128.268 Thread 0x00000000023e3800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000000003446028 method=java.util.regex.Pattern$Ques.match(Ljava/util/regex/Matcher;ILjava/lang/CharSequence😉Z @ 68
Event: 128.269 Thread 0x00000000023e3800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000000003446028 method=java.util.regex.Pattern$Ques.match(Ljava/util/regex/Matcher;ILjava/lang/CharSequence😉Z @ 68
Event: 128.272 Thread 0x00000000023e3800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x0000000003446028 method=java.util.regex.Pattern$Ques.match(Ljava/util/regex/Matcher;ILjava/lang/CharSequence😉Z @ 68
Event: 129.012 Thread 0x00000000023e3800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000048f675c method=net.minecraft.client.renderer.ActiveRenderInfo.func_151460_a(Lnet/minecraft/world/World;Lnet/minecraft/entity/EntityLivingBase;F)Lnet/minecraft/block/Block; @ 43
Event: 129.013 Thread 0x00000000023e3800 Uncommon trap: reason=unloaded action=reinterpret pc=0x0000000003256c24 method=shadersmodcore.client.ShadersTess.preDrawArray(Lnet/minecraft/client/renderer/Tessellator😉V @ 154
Event: 129.013 Thread 0x00000000023e3800 Uncommon trap: reason=unloaded action=reinterpret pc=0x0000000003249190 method=shadersmodcore.client.ShadersTess.postDrawArray(Lnet/minecraft/client/renderer/Tessellator😉V @ 9
Event: 129.020 Thread 0x00000000023e3800 Uncommon trap: reason=unloaded action=reinterpret pc=0x0000000003285904 method=shadersmodcore.client.ShadersTess.preDrawArray(Lnet/minecraft/client/renderer/Tessellator😉V @ 154
Event: 129.024 Thread 0x00000000023e3800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000048f675c method=net.minecraft.client.renderer.ActiveRenderInfo.func_151460_a(Lnet/minecraft/world/World;Lnet/minecraft/entity/EntityLivingBase;F)Lnet/minecraft/block/Block; @ 43
Event: 129.038 Thread 0x00000000023e3800 Uncommon trap: reason=class_check action=maybe_recompile pc=0x00000000048f675c method=net.minecraft.client.renderer.ActiveRenderInfo.func_151460_a(Lnet/minecraft/world/World;Lnet/minecraft/entity/EntityLivingBase;F)Lnet/minecraft/block/Block; @ 43
Internal exceptions (10 events):
Event: 128.970 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c3b798) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.972 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c3c4f8) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.973 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c3d430) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.974 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c3e190) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.975 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c3f0c8) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.976 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c3fe28) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.977 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c40d60) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.978 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c41ac0) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.979 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c42998) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Event: 128.980 Thread 0x00000000023e3800 Exception <a 'java/io/FileNotFoundException'> (0x00000000c1c436a0) thrown at [D:\re\workspace\8-2-build-windows-amd64-cygwin\jdk8u25\1677\hotspot\src\share\vm\prims\jni.cpp, line 716]
Events (10 events):
Event: 129.020 Thread 0x00000000023e3800 DEOPT UNPACKING pc=0x000000000252556a sp=0x00000000023dc700 mode 2
Event: 129.024 Thread 0x00000000023e3800 Uncommon trap: trap_request=0xffffffde fr.pc=0x00000000048f675c
Event: 129.024 Thread 0x00000000023e3800 DEOPT PACKING pc=0x00000000048f675c sp=0x00000000023dc420
Event: 129.024 Thread 0x00000000023e3800 DEOPT UNPACKING pc=0x000000000252556a sp=0x00000000023dc3b8 mode 2
Event: 129.037 Thread 0x00000000023e3800 Uncommon trap: trap_request=0xffffffde fr.pc=0x00000000048f675c
Event: 129.038 Thread 0x00000000023e3800 DEOPT PACKING pc=0x00000000048f675c sp=0x00000000023dc420
Event: 129.038 Thread 0x00000000023e3800 DEOPT UNPACKING pc=0x000000000252556a sp=0x00000000023dc3b8 mode 2
Event: 129.038 Thread 0x00000000023e3800 Uncommon trap: trap_request=0xffffffde fr.pc=0x00000000048f675c
Event: 129.038 Thread 0x00000000023e3800 DEOPT PACKING pc=0x00000000048f675c sp=0x00000000023dc550
Event: 129.038 Thread 0x00000000023e3800 DEOPT UNPACKING pc=0x000000000252556a sp=0x00000000023dc4e8 mode 2
Dynamic libraries:
0x00007ff7929a0000 - 0x00007ff7929d4000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\javaw.exe
0x00007ff8892c0000 - 0x00007ff88946c000 C:\Windows\SYSTEM32\ntdll.dll
0x00007ff886b40000 - 0x00007ff886c7a000 C:\Windows\system32\KERNEL32.DLL
0x00007ff8869e0000 - 0x00007ff886aef000 C:\Windows\system32\KERNELBASE.dll
0x00007ff885160000 - 0x00007ff8851e8000 C:\Windows\system32\apphelp.dll
0x00007ff883420000 - 0x00007ff88346f000 C:\Windows\AppPatch\AppPatch64\AcGenral.DLL
0x00007ff887d60000 - 0x00007ff887e07000 C:\Windows\system32\msvcrt.dll
0x00007ff886400000 - 0x00007ff88642b000 C:\Windows\SYSTEM32\SspiCli.dll
0x00007ff887710000 - 0x00007ff887761000 C:\Windows\system32\SHLWAPI.dll
0x00007ff887330000 - 0x00007ff8874a1000 C:\Windows\system32\USER32.dll
0x00007ff887950000 - 0x00007ff887ac8000 C:\Windows\system32\ole32.dll
0x00007ff887eb0000 - 0x00007ff8892bf000 C:\Windows\system32\SHELL32.dll
0x00007ff885f80000 - 0x00007ff885f9e000 C:\Windows\SYSTEM32\USERENV.dll
0x00007ff887660000 - 0x00007ff887705000 C:\Windows\system32\ADVAPI32.dll
0x00007ff87c6e0000 - 0x00007ff87c6fb000 C:\Windows\SYSTEM32\MPR.dll
0x00007ff887510000 - 0x00007ff887647000 C:\Windows\system32\RPCRT4.dll
0x00007ff886c80000 - 0x00007ff886cd7000 C:\Windows\SYSTEM32\sechost.dll
0x00007ff887080000 - 0x00007ff887256000 C:\Windows\SYSTEM32\combase.dll
0x00007ff887790000 - 0x00007ff8878d4000 C:\Windows\system32\GDI32.dll
0x00007ff886620000 - 0x00007ff886634000 C:\Windows\SYSTEM32\profapi.dll
0x00007ff884960000 - 0x00007ff8849ff000 C:\Windows\SYSTEM32\SHCORE.dll
0x00007ff887b30000 - 0x00007ff887b64000 C:\Windows\system32\IMM32.DLL
0x00007ff886e90000 - 0x00007ff886fc9000 C:\Windows\system32\MSCTF.dll
0x00007ff882880000 - 0x00007ff882ada000 C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.9600.17031_none_6242a4b3ecbb55a1\COMCTL32.dll
0x00007ff886380000 - 0x00007ff8863fc000 C:\Windows\system32\guard64.dll
0x00007ff887d50000 - 0x00007ff887d57000 C:\Windows\system32\PSAPI.DLL
0x00007ff886360000 - 0x00007ff88636a000 C:\Windows\SYSTEM32\VERSION.dll
0x00007ff886350000 - 0x00007ff88635a000 C:\Windows\SYSTEM32\fltlib.dll
0x00007ff886320000 - 0x00007ff886350000 C:\Windows\SYSTEM32\ntmarta.dll
0x000000005e240000 - 0x000000005e312000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\msvcr100.dll
0x000000005bc80000 - 0x000000005c4da000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\server\jvm.dll
0x00007ff87da60000 - 0x00007ff87da69000 C:\Windows\SYSTEM32\WSOCK32.dll
0x00007ff880610000 - 0x00007ff88062f000 C:\Windows\SYSTEM32\WINMM.dll
0x0000000002180000 - 0x00000000021d8000 C:\Windows\system32\WS2_32.dll
0x00007ff8803f0000 - 0x00007ff88041a000 C:\Windows\SYSTEM32\WINMMBASE.dll
0x00000000021e0000 - 0x00000000021e9000 C:\Windows\system32\NSI.dll
0x00000000021f0000 - 0x000000000223a000 C:\Windows\SYSTEM32\cfgmgr32.dll
0x00007ff8853c0000 - 0x00007ff8853e6000 C:\Windows\SYSTEM32\DEVOBJ.dll
0x000000005e230000 - 0x000000005e23f000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\verify.dll
0x000000005e200000 - 0x000000005e228000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\java.dll
0x000000005e1e0000 - 0x000000005e1f6000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\zip.dll
0x000000005e1d0000 - 0x000000005e1dd000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\management.dll
0x000000005e1b0000 - 0x000000005e1ca000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\net.dll
0x00007ff885d70000 - 0x00007ff885dc8000 C:\Windows\system32\mswsock.dll
0x000000005e190000 - 0x000000005e1a1000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\nio.dll
0x00007ff86da80000 - 0x00007ff86da94000 C:\Windows\system32\napinsp.dll
0x00007ff86da60000 - 0x00007ff86da79000 C:\Windows\system32\pnrpnsp.dll
0x00007ff881450000 - 0x00007ff88146b000 C:\Windows\system32\NLAapi.dll
0x00007ff885af0000 - 0x00007ff885b93000 C:\Windows\SYSTEM32\DNSAPI.dll
0x00007ff879b20000 - 0x00007ff879b2c000 C:\Windows\System32\winrnr.dll
0x000000005cd60000 - 0x000000005cd86000 C:\Program Files\Bonjour\mdnsNSP.dll
0x00007ff880630000 - 0x00007ff880659000 C:\Windows\SYSTEM32\Iphlpapi.DLL
0x00007ff880600000 - 0x00007ff88060a000 C:\Windows\SYSTEM32\WINNSI.DLL
0x00007ff86da40000 - 0x00007ff86da53000 C:\Windows\system32\wshbth.dll
0x00007ff87b590000 - 0x00007ff87b599000 C:\Windows\System32\rasadhlp.dll
0x00007ff87fd80000 - 0x00007ff87fde8000 C:\Windows\System32\fwpuclnt.dll
0x000000005a640000 - 0x000000005a657000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\unpack.dll
0x0000000180000000 - 0x0000000180051000 C:\Users\atlan_000\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.2.1291\1.7.10-Forge10.13.2.1291-natives-340732017095463\lwjgl64.dll
0x00007ff87e5d0000 - 0x00007ff87e6f1000 C:\Windows\SYSTEM32\OPENGL32.dll
0x00007ff883dd0000 - 0x00007ff883dfc000 C:\Windows\SYSTEM32\GLU32.dll
0x00007ff882440000 - 0x00007ff882534000 C:\Windows\SYSTEM32\DDRAW.dll
0x00007ff883db0000 - 0x00007ff883db9000 C:\Windows\SYSTEM32\DCIMAN32.dll
0x00007ff885fa0000 - 0x00007ff885fbe000 C:\Windows\SYSTEM32\CRYPTSP.dll
0x00007ff885a10000 - 0x00007ff885a45000 C:\Windows\system32\rsaenh.dll
0x00007ff886030000 - 0x00007ff886056000 C:\Windows\SYSTEM32\bcrypt.dll
0x000000001a720000 - 0x000000001a780000 C:\Windows\system32\bcryptprimitives.dll
0x00000000022c0000 - 0x00000000022ca000 C:\Windows\SYSTEM32\CRYPTBASE.dll
0x00007ff87f7b0000 - 0x00007ff87f7c4000 C:\Windows\SYSTEM32\dhcpcsvc6.DLL
0x00007ff8803d0000 - 0x00007ff8803e9000 C:\Windows\SYSTEM32\dhcpcsvc.DLL
0x000000005bae0000 - 0x000000005bc78000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\awt.dll
0x00007ff887260000 - 0x00007ff887321000 C:\Windows\system32\OLEAUT32.dll
0x00007ff885290000 - 0x00007ff8853b1000 C:\Windows\system32\uxtheme.dll
0x00007ff884790000 - 0x00007ff8847b0000 C:\Windows\system32\dwmapi.dll
0x000000001dbb0000 - 0x000000001e37a000 C:\Windows\SYSTEM32\ig7icd64.dll
0x00007ff871020000 - 0x00007ff871472000 C:\Windows\SYSTEM32\igdusc64.dll
0x00007ff885280000 - 0x00007ff88528a000 C:\Windows\SYSTEM32\kernel.appcore.dll
0x00007ff870f00000 - 0x00007ff870f8d000 C:\Windows\SYSTEM32\mscms.dll
0x00007ff880260000 - 0x00007ff8802a1000 C:\Windows\SYSTEM32\icm32.dll
0x00007ff8865c0000 - 0x00007ff886605000 C:\Windows\SYSTEM32\powrprof.dll
0x0000000070a40000 - 0x0000000070adc000 C:\Users\atlan_000\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.2.1291\1.7.10-Forge10.13.2.1291-natives-340732017095463\avutil-ttv-51.dll
0x0000000065980000 - 0x00000000659d6000 C:\Users\atlan_000\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.2.1291\1.7.10-Forge10.13.2.1291-natives-340732017095463\swresample-ttv-0.dll
0x000000006eb80000 - 0x000000006ec50000 C:\Users\atlan_000\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.2.1291\1.7.10-Forge10.13.2.1291-natives-340732017095463\libmp3lame-ttv.dll
0x00007ff861fa0000 - 0x00007ff863344000 C:\Users\atlan_000\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.2.1291\1.7.10-Forge10.13.2.1291-natives-340732017095463\libmfxsw64.dll
0x00007ff8718c0000 - 0x00007ff8719eb000 C:\Users\atlan_000\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.2.1291\1.7.10-Forge10.13.2.1291-natives-340732017095463\twitchsdk.dll
0x00007ff87efe0000 - 0x00007ff87f228000 C:\Windows\SYSTEM32\WININET.dll
0x00007ff87f230000 - 0x00007ff87f4f7000 C:\Windows\SYSTEM32\iertutil.dll
0x000000005ba40000 - 0x000000005ba64000 C:\Users\atlan_000\Downloads\runtime\jre-x64\1.8.0_25\bin\sunec.dll
0x000000001c410000 - 0x000000001c474000 C:\Users\atlan_000\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.2.1291\1.7.10-Forge10.13.2.1291-natives-340732017095463\OpenAL64.dll
0x00007ff886fd0000 - 0x00007ff887074000 C:\Windows\SYSTEM32\clbcatq.dll
0x00007ff881fd0000 - 0x00007ff882032000 C:\Windows\System32\MMDevApi.dll
0x00007ff872ed0000 - 0x00007ff872f57000 C:\Windows\SYSTEM32\dsound.dll
0x00007ff87ffa0000 - 0x00007ff88001e000 C:\Windows\SYSTEM32\AUDIOSES.DLL
0x00007ff87ca40000 - 0x00007ff87cbc8000 C:\Windows\SYSTEM32\dbghelp.dll
VM Arguments:
jvm_args: -XX:HeapDumpPath=MojangTricksIntelDriversForPerformance_javaw.exe_minecraft.exe.heapdump -Xmx1G -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M -Djava.library.path=C:\Users\atlan_000\AppData\Roaming\.minecraft\versions\1.7.10-Forge10.13.2.1291\1.7.10-Forge10.13.2.1291-natives-340732017095463
java_command: net.minecraft.launchwrapper.Launch --username SenGoku4321 --version 1.7.10-Forge10.13.2.1291 --gameDir C:\Users\atlan_000\AppData\Roaming\.minecraft --assetsDir C:\Users\atlan_000\AppData\Roaming\.minecraft\assets --assetIndex 1.7.10 --uuid 771604ef4bbc40f086074820fb68841e --accessToken 13facd241ec14056b485834736faec93 --userProperties {} --userType legacy --tweakClass cpw.mods.fml.common.launcher.FMLTweaker
java_class_path (initial): C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\net\minecraftforge\forge\1.7.10-10.13.2.1291\forge-1.7.10-10.13.2.1291.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\net\minecraft\launchwrapper\1.11\launchwrapper-1.11.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\ow2\asm\asm-all\5.0.3\asm-all-5.0.3.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\com\typesafe\akka\akka-actor_2.11\2.3.3\akka-actor_2.11-2.3.3.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\com\typesafe\config\1.2.1\config-1.2.1.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-actors-migration_2.11\1.1.0\scala-actors-migration_2.11-1.1.0.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-compiler\2.11.1\scala-compiler-2.11.1.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\plugins\scala-continuations-library_2.11\1.0.2\scala-continuations-library_2.11-1.0.2.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\plugins\scala-continuations-plugin_2.11.1\1.0.2\scala-continuations-plugin_2.11.1-1.0.2.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-library\2.11.1\scala-library-2.11.1.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-parser-combinators_2.11\1.0.1\scala-parser-combinators_2.11-1.0.1.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-reflect\2.11.1\scala-reflect-2.11.1.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-swing_2.11\1.0.1\scala-swing_2.11-1.0.1.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\org\scala-lang\scala-xml_2.11\1.0.2\scala-xml_2.11-1.0.2.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\net\sf\jopt-simple\jopt-simple\4.5\jopt-simple-4.5.jar;C:\Users\atlan_000\AppData\Roaming\.minecraft\libraries\lzma\lzma\0.0.1\lzma-0.0.1.jar;C:\U
Launcher Type: SUN_STANDARD
Environment Variables:
PATH=C:\ProgramData\Oracle\Java\javapath;C:\Program Files (x86)\Intel\TXE Components\TCS\;C:\Program Files\Intel\TXE Components\TCS\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files\Acer\Remote Files\
USERNAME=Catalina Emens
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 55 Stepping 8, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows 8.1 , 64 bit Build 9600
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 55 stepping 8, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, clmul, erms, tsc, tscinvbit
Memory: 4k page, physical 8269008k(5259344k free), swap 9579728k(5986248k free)
vm_info: Java HotSpot(TM) 64-Bit Server VM (25.25-b02) for windows-amd64 JRE (1.8.0_25-b18), built on Oct 7 2014 14:25:37 by "java_re" with MS VC++ 10.0 (VS2010)
time: Wed May 20 18:45:56 2015
elapsed time: 129 seconds (0d 0h 2m 9s)
Could you be a darling and help me? I've tried changing the permissions of the .dll file and yes all my drivers are up to date, I made sure of that :3
I know very well how to install everything, and I made sure to have done so correctly, and I have, so it not that :/
I know they are, but that's why I want to fix it, some other forums said it was a permissions error, but I tried to fix that and it didnt work
Yes I am, one of the first things I made sure of
As I stated, a clean reinstall usually fixes this kind of stuff...... does it work fine without Shaders? Are you running the latest launcher from minecraft.net ? Do delete .minecraft to reinstall, though I think you already knew 😛.
