Need help with motherboard and gpu compatability
noblesse711
5
I currently have a m4n68t motherboard and for the life of me i cant figure out if the gpu im looking to buy will work on it. I'm looking to buy a sapphire Rx 560 pulse 2gb but i don't know if my motherboard can support it, been researching all night but i'm too new at building to know anything for sure, please help
You MB has one pcie2.0X16, in theory as long as the MB has pcie 2.0X16 0r 3.0X16, the rx560 will fit. But keep in mind your MB has old version BIOS, which was from 2011, and it is old. So the newer GPU may or may not run well. In other word nobody will know until you try it out. Sorry.
If you want to try, make sure you can return the GPU if they don't work out. Or borrow the GPU from your friend, you will know the newer gen GPU will work with your MB or not.
