Question Need help with Msi memory try it ddr4 overclock
bigferdi
28
i have a system running corsair rgb pro 2x8gb 3000mhz c16,realized overclocking to 3200mhz with Msi memory try it
gives a stable 60fps in Ac Odyssey medium ultra settings.The isssue is Msi memory try it ups the dram voltage
to 1.4v from stock XMP 1.35v. I want to know if 1.4v will be ok for my ram to run on.
Havent done any memory stress test but seems to be stable so far in Ac Odyssey(4hrs of playtime).
Need Your opinions.
FULL SPECS
I5 8400 3.8GHZ
2X8GB CORSAIR RGB PRO 3000MHZ C16
SANDISK 256 SSD
THERMALTAKE SMART 600W PSU
MSI Z370 GAMING PLUS
GTX 1070(GYGABYTE)
1.4v is nothing. You can run much higher than that on these memory controllers which were designed to also use legacy DDR3 on rare mother boards. More voltage will simply use more power and thus run hotter.
You could also try tightening timings for more performance in your CPU bound scenario.
so you mean 1.4v wont fry the memory?thats what scares me
