SOLVED: I ended up getting new RAM and not a single BSOD since then.
Hello guys,
First of all, thanks so much for the help.
Since the last week, I've been getting BSODs, and I'm not sure what to do anymore. Usually of this kind:
PAGE_FAULT_IN_NONPAGED_AREA
Code: 0x00000050
Caused by Driver: ntoskrnl.exe
MEMORY_MANAGEMENT
Code: 0x0000001a
SYSTEM-SERVICE_EXCEPTION
Code: 0x0000003b
IRQL_NOT_LESS_OR_EQUAL
Code: 0x0000000a
What I've tried so far:
Specs:
Hello guys,
Code: 0x00000050
MEMORY_MANAGEMENT
Code: 0x0000001a
Code: 0x0000003b
Code: 0x0000000a
- MemTest86: 6 runs overnight with no errors
- Windows Memory Diagnostic tool: 2 runs, no errors
- Windows 10 clean reinstall
- sfc /scannow, etc
- chkdsk /f, etc
- Resetting BIOS to default/optimized settings (no overclock and nothing fancy activated that might cause system instability)
- Disabling Windows pagefile (still got BSODs)
Specs:
- CPU: Ryzen 3950X (default clocks and voltages)
- RAM: 32 GB DDR4 @3600 MHz (default timings, etc)
- MOBO: MSI MEG X570 Unify
- GPU: Nvidia 2070 Super (default clocks, etc)
- HDD1: 1 TB Nvme PCIe 4.0 M.2 2280 (where Windows is installed and pagefile is located by default )
- HDD2: 1 TB SSD SATA (downloads, other unimportant data, etc)
- HDD3: 256 GB SSD SATA (had Ubuntu previously installed in it, but ended up formatting it, I might remove it later since I'm not using it)
